stock jet size help 85 xj700n
Discussion in 'XJ Technical Chat' started by hardtailed81/85xj700, Sep 21, 2015.
Tags:
  1. hardtailed81/85xj700
    hardtailed81/85xj700 New Member
    missouri
    i have a carb off an 81 750 maxim that im putting on a 85 700n I know the jet sizes aren't right
    for the 700 ........110/40 195/50 is whats in the I assume hitachi carb
    what are the stock jet sizes straight from the factory on a 85xj700n
    anyone know ???????
    main jet
    #107: all XJ700 non-X models.
    www.xj4ever.com part number
    HCP6317 Aftermarket Hitachi brass #107 MAIN FUEL JET, stock size for XJ700 non-X models,
    main air jet
    #70: all XJ700 non-X models, XJ750RL Seca models, and XJ750E-II models.
    HCP6311 Aftermarket Hitachi brass MAIN AIR JET #70, original size for all XJ700 non-X (air-cooled) models, XJ750RL Seca models, and XJ750E-II models.
  3. XJ550H
    PILOT FUEL JET,
    #36.5: all XJ700 non-X models.
    HCP6321 Aftermarket Hitachi brass #36.5 PILOT FUEL JET,
    Hitachi pilot air jets
    #210: all XJ700 non-X models.
    HCP6296 Aftermarket Hitachi brass PILOT AIR JET #210, original size for all 1985-86 XJ700 air-cooled engines.
  4. hardtailed81/85xj700
    missouri
    Thanks my man
    Helps alot
  5. XJ550H
    remeber this is stock jets for stock bike .
    do you have a stock bike ? no pods stock exhaust? is so your jets will/may be different for proper running
  6. hardtailed81/85xj700
    missouri
    , post: 477824, member: 16564"]remeber this is stock jets for stock bike .
    do you have a stock bike ? no pods stock exhaust? is so your jets will/may be different for proper running[/QUOTE]
    No not stock Im going to have pods
    And right at the moment no muffler just straight pipes I needed a starting point for the jets I know il
  7. hardtailed81/85xj700
    missouri
    Have to use the formula to get it right
    just curios you know the jet specs
    for an 81 xj650 maxim
  8. chacal
    Towards the end of this page are all of the carb specs for every different model:
    http://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/
    Note that an HSC32 carb (XJ650 and XJ750 models) is not going to fit/work properly on an XJ700 model (which uses HSC33 series carbs). While it MIGHT (and even that is a big question mark) physically fit into an HSC33 carb rack, besides the jetting issues, there is the problem that it is a physically smaller (throat/venturi) carb and you'll never be able to synch and tune such a mis-matched rack of carbs.....
  9. hardtailed81/85xj700
    missouri
    Ive looked but cant find the markings to determine which carb ive got for sure
    but yah that sucks if so
    I was hoping to useit
    it fit by swapping the two end pieces black adapter s
    from the 750 they curve inward slightly
