Stranger Danger!
Discussion in 'For Sale, Trade/Swap, Wanted' started by ecologito, Jul 28, 2014.
  1. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
  2. hogfiddles
    It still has the rear brake assembly, rod, and pedal....I would assume that's how they stop.
    I wonder why they didn't pull off the front rotor since they pulled the front brake system.
    dave
  3. jcro61
    jcro61 Member
    Massachusetts
    Running no front brake is not as bad as you make it seem.
  4. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    On any vehicle the front brake is 70-80% of your braking. Giving up the vast majority of your braking capacity seems pretty damn bad to me.
    Specifically on a bike you essentially give up the ability to do an effective emergency stop.
    So, tell me, how is it not as bad as that?
  5. mtnbikecrazy55
    plus it'd be goofy to ride a bike with only one lever
  6. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    I believe what jc was referring to was the fact that finding and installing the front brake isn't hard to do.
  7. Polock
    " give up the ability to do an effective emergency stop. " all stops are emergency stops
    Fred Flintstone did ok with no front brakes
  8. quebecois59
    I wouldn't pay that kind of money for a bike without front brakes
  9. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    Brakes! Who needs Brakes!! We got throttle...and the high maneuverability of a completely chopped up bike...
    betcha he really misses doing front wheel stands....lol
  10. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Fred was in a cage.
  11. Polock
  12. Xjrider92117
    San Jose Ca
    Well looks like they both rode and had no brakes.
    8O :D :D
  13. jcro61
    jcro61 Member
    Massachusetts
    I have had chops with no front brakes, it is not as bad as you make it seem, to this day I use my rear brake primarily....
  14. Kickaha
    New Zealand
    I personally don't understand why someone would reduce the effectiveness of their bikes stopping power by 70 + % and increase their stopping distance just for fashion/looks
    I guess you'd just have to compenate for it with being more cautious in your riding, if you primarily use your rear brake when you have both front and back brakes then you're doing it wrong
  15. JPaganel
    Minneapolis
    Then you are doing it wrong.
    If you stick to riding in parades it's OK. If you ride on the speedway wrapped in safety gear and contained by crash barriers, it's OK. Riding a bike with three quarters of it's brakes missing on the street is just not very smart.
    The idea that the front brakes are the most of your braking is not something we say. It's a fact.
  16. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    The few times that I had to slam on my brakes because of some cager not paying attention, I was so glad that I had front brakes. Emergency stops with only a rear brake are impossible. I went out and tried to only use the rear brake to stop on my street. Didn't stop to quickly. I love my rear brake, but only when it is coupled with my wonderul front brake.
  17. jcro61
    jcro61 Member
    Massachusetts
    Come ride with us and you will see
  18. Orange-n-Black
    Memphis Area
    Personally, I'd rather have a front brake.
    Your original rear brake setting is minimal on a two brake setup. I'm thinking that someone who has a rear brake only, would adjust that brake to work better than the regular setting with a two brake setup. So If you adjusted your rear brake more aggressively, you might find that it can stop your bike quite well.
  19. Polock
    I try to adjust the back brake to work as well as possible, just because I should be.
  20. FtUp
    FtUp Well-Known Member
    pacific northwest
    the problem with this scenario is that if you lock up the rear tire (and you will), you are going for a ride you don't want to take.
    CN
