Stripped bolt?
Discussion in 'XJ Technical Chat' started by nickbrit16, Jun 11, 2015.
  1. nickbrit16
    nickbrit16 Member
    Ohio
    Eorking on the Xj650 today. The left side brace that holds on the passenger footpeg bolt just keeps spinning. I've used PB Blaster and got it broke loose but it just keeps turning like the bolt is free spinning in there or something. Any advice?
    I've attached a picture of the bolt.
    Put a wrench on the other side of the fastener too.
  3. nickbrit16
    nickbrit16 Member
    Ohio
    Got it, wow it took me a little while to figure that one out, duh!
    Thanks k-moe, as always.
  4. nickbrit16
    nickbrit16 Member
    Ohio
    Here's a pic
  5. nickbrit16
    nickbrit16 Member
    Ohio
    Here's a pic
  6. nickbrit16
    nickbrit16 Member
    Ohio
    Here's a pic
  7. chacal
    You do know that bolt supports the rear of the engine, correct?
  8. nickbrit16
    nickbrit16 Member
    Ohio
    Correct
  9. k-moe
    The question is (and I'm not entirely sure of the answer) why is there that space between the foot peg mount and the frame lug? I don't recall there being a spacer behind the mount.
  10. k-moe
    Hold on a second. I think I've got it. Does this bike happen to have been made into a cafe racer type thing? Are the only footpegs mounted at the rear of the aluminum bracket? In stock form that space would be filled by the rider's foot peg mount.
  11. nickbrit16
    nickbrit16 Member
    Ohio
    You are correct. That's where the foot pegs mount, in between the frame and the bracket. Thank you sir.
