stripped carb hat screw
Discussion in 'XJ Technical Chat' started by gomerkyle, Jul 16, 2011.
  1. gomerkyle
    gomerkyle New Member
    So I've decided it's time that the carbs come off this '81 XJ650LH. Got them apart (not off the rack), bowls and floats apart. Hats are off #1,#3,#4. On carb #2, two of the screws are stripped. One is a little worn, the other, don't think I'll be able to get it out. How would you guys go about removing this screw? By the way, it's the flat head part that is stripping, not the philips head.
  2. TIMEtoRIDE
    Get on it sideways with a 10" Vice Grip. You can actually crush the screw head - the metal is that soft.
    Go to any hardware store and get (order) stainless allen cap screws (metric) and a jar of Anti-Seize.
  3. darkfibre
    darkfibre Member
    Perth, Australia
    Perfect answer. If you dont have vice grips but have a vice, clamp the screw head in the vice and turn the carb to undo.
  4. gomerkyle
    I actually got em out with some pb blaster, and then used a rubber band for some extra grip. I do plan on ordering all new screws, as well as at least one float bowl gasket that I ripped apart while trying to get it off the carb body. Thanks for the tip though, I'm sure that method works like a charm since these screws are so damn soft like you said (if they weren't I wouldn'tve had this problem in the first place lol). Again thanks for the input
  5. hogfiddles
    My preferred way.....using small drill bits in increasing size, drill it out stopping just at the thread inside diameter. Clean and re-chase the threads, replace the screw.
    Dave
  6. MaximumX
    MaximumX Member
    Ottawa, Canada
    I just use a dremel to make a deeper slot to get more bite with the flat-head bit. A little PB or Kroil doesn't hurt either...
    +1 on the stainless socket-head replacements.
  7. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Dropping $20 on a set of easy outs doesn't hurt either.
    +1 on the allen heads and anti-sieze. You should be putting anti-sieze on any screw/bolt that doesn't get thread locker. It should become your best friend.... and you'll be thankful you spent the extra minute when those screws come right out 5+ years from now.....
  8. badfish502
    badfish502 Member
    Id also suggest an impact driver. I never could have gotten my carbs apart to clean them without one!
    Jay
  9. skw1972
    skw1972 Member
    Milton Florida
    had the same problem, should have came here first (as usual) I got mine off by cutting into it with a hacksaw blade and a better scewdriver. Im gonna do the stainless allen tip gig, I like that
  10. RickCoMatic
    Carb HAT Screws?
    If the Crosses are buggered and a Screwdriver don't work, ...
    I grab them with Needle-nosed Vice-Grips.
    (Sometimes I grab them with the Needle-nosed Vice-Grips and it resists.
    That's when I grab it TIGHT with the Needle-Vice-Grips and smack the Needles with a Hammer Handle).
    Throw-away any Fastener less than PERFECT.
    If you rehabbing Carbs, ...
    Do the Stainless Kit from chacal.
