Stripping Down XJ900 Forks - 26 Pics
Discussion in 'XJ Technical Chat' started by Alive, Apr 22, 2007.
  1. Alive
    Alive Active Member
    Queensland, Australia
    Yup I've been at it again....
    Later model forks than my bike with no Anti-Dive system....
  2. AdeXJ
    AdeXJ Member
    Kent, UK
    Nice job, good pics.
    They looks like XJ900F forks (ca. 1991-93) - I have stripped mine down more than a few times trying to get em stiffer.
    On mine, these seem to work better than the set with anti-dive.
  3. Alive
    Alive Active Member
    The forks I have on now have the anti dive and I'm hoping that these ones (once back together) are a whole lot better than what I have now
  4. oby_2
    oby_2 Member
    Sydney, Australia
    Alive,
    What was the outcome mate? I have a 83 XJ900 and the front forks are terrible. I haven't decided whether I'm better rebuilding the current ones or looking for a replacement.
    Cheers
  5. RickCoMatic
    I redid the Front Forks on my 1983 XJ900RK (USA Model)
    The Damper has a different Oil Lock Piece than I'm seeing in your Photographs. I replaced the Slider and "Shimmed" the Nylon Bush.
    I Pressed a 10-thousandths Piece of PlastiGuage down to .0015 in my Micrometer. Slip the "Shim" behind the Slider and the Front End (along with Progressive Springs and and additional 2.5 cm of pre-load) is Fabulous over the Road and lessens Vibration)
    The Anti-dive's are Simple to Overhaul.
    The Anti-dives are Difficult to Strip.
    The O-ring secured Top beneath the Circlip is a BEAR to get moving out.
    Once it comes free ...
    You only need to refinish the Inside Diameter of a Nylon Bushing to Allow the Cylindrical Piston to have "Travel" again ... and they work beautifully!
  6. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    So where did you get that neat little socket tool? There is going to be some interest in that. Nice pics of how those look when they start to leak. Rust and crud that you couldn't even see takes them out.
  7. Alive
    Alive Active Member
    Haven't finished them yet... Got put on hold when the weather started cooling down and we went on holiday, then shifted... Sometime soon I might actually find the time to finish them off
  8. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Great pics ..... planning to do the seals on my XS this weekend (if my parts come in)
  9. Dookus
    Dookus New Member
    What is the socket on the end of the extension bars?, my forks are very similar and I'm presently trying to pull them, the bottom allen bolt
    just spins.
  10. Dookus
    Dookus New Member
    Found it, it is a splined recessed bolt, a 21ml allen key fitted.
  11. Alive
    Alive Active Member
  12. Polock
    were the seals you took out upside down ?
  13. Alive
    Alive Active Member
    No... Why do you ask?
  14. Polock
    shouldn't the open side of the seal with the spring go towards the oil
    and the flat side where the numbers usually are go up towards the air?
    or am i not seeing something right
  15. Alive
    Alive Active Member
    These seals had hollow undersides... the numbers were facing up on the rim just below the spring... They were unusual.
  16. Polock
    ok, i guess their all different here is a excellent article on the topic, you might like the one on kidney belts too
    :wink:
  17. Alive
    Alive Active Member
    Awww man you really know where to find all the good oil... *wanders off to do some "READING"*
  18. Dookus
    Dookus New Member
    That's a good tool, can't find it in Australia though. seller does not post international.
  19. Alive
    Alive Active Member
    This one does
    http://cgi.ebay.com/ebaymotors/Motion-P ... 27b0e78e65
    So does this one
    http://cgi.ebay.com/ebaymotors/Motion-P ... 27b0e779fd
    and this one
    http://cgi.ebay.com/ebaymotors/INTERNAL ... 19bb062424
    http://cgi.ebay.com/ebaymotors/Tusk-Hex ... 27ab0d1241
    And then there's the one in Australia
    http://cgi.ebay.com.au/Motorcycle-front ... 43a0ffe12f
    I searched for "hex axle tool"
  20. jeishen
    jeishen Member
    North Port, FL
    @polock I was checking out the kidney belt link about half way through I forgot what I was looking at. In other words good link ;-)
