Stripping Speedo!
Discussion in 'XJ Technical Chat' started by Rsk_141, Mar 25, 2018.
  1. Rsk_141
    Rsk_141 Member
    Scotland
    Changed plugs all good went for a spin, managed to snap the Speedo Needel,
    Can they be replaced by an amature
    Or do I have to send it away, quite keen to keep original milage
    Regards
    Gary
    glue a tooth pick or tube from carb cleaner on to whats left . needle has a brass bushing in it which sometimes pulls out of needle when trying to remove it. pulling it can ruin the speedo
    if you swap speedos you can roll the dials to match your mileage
  3. Jetfixer
    ^^^^+1 use a flat toothpick super glues in place a little testors model paint in orange or red .
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    I wanted to swap faces on a speedo a few years ago and ended up with a broken useless speedo after attempting to pull the needle off. I'm not ham fisted nor was anything forced but due to the way it was initially assembled there was no chance I was going to get it right. I'm not familiar with that exact one but if the needle is pressed onto a knurled shaft like mine was, I don't see any way to get it back on properly. I obtained a good replacement and then set the mileage to match. Pretty easy to do and you can clean up and lube the gears once apart. The methods previously described work too if you're not looking to have it perfect.
  5. Rsk_141
    Rsk_141 Member
    Scotland
    Thanks guys,
    will strip it this weekend and see how I go, will keep you posted.
  6. Jetfixer
    If you remove 2 screws on the face plate put 2 screw drivers under plate and gently pry up. Needle should pop off shaft without bending shaft if your careful.
