Stuck Carburetor Bowl
Discussion in 'XJ Technical Chat' started by Gary Potter, Dec 13, 2021.
  1. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I am rebuilding some carburetors for a 82 XJ650 and the number 2 bowl won't come off. I've tried Kroil, carb cleaner, tapping with a rubber hammer and it's still won't come off. Would soaking it in a carb cleaner like Gunk damage the floats? The floats on the other carbs don't look like metal, more like a black plastic. Thanks for any input here.
  2. Dan Gardner
    Minneapolis, MN
    The 4 screws that hold the bowl on are stuck? Or the drain screw?
  3. Dan Gardner
    Minneapolis, MN
    Are you using a proper JIS screwdriver? If not, that is the first requirement.
  4. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I got it off, thanks for your input
