Stuck "hard" Carb float bowl drain screws
Discussion in 'XJ Technical Chat' started by proad, Mar 31, 2007.
  1. proad
    proad Member
    bartlesville
    81 Seca 750 " Hitachis" Any one have experience removing stuck carb float bowl drain screws?
    I have new ones, so " messing up" these is not a problem, as long as threads in holes remain good/usable. thanks-
    john
  2. gremlin484
    gremlin484 Member
    Omaha, Nebraska
    I to have the same issue, but I just guessed on the float height instead of using a gauge...
    Where did you get the new screws? Or are they just your standard set screws?
  3. faighaigh
    faighaigh Member
    Malaga . Spain
    I had the same problem awhile ago with stuck drain screws on my Hitachi carbs. Tried all the suggestions from the blokes on here but in the end had to use an easyout which worked a treat. Got them out without any damage to the carbs and the stainless steel screws I bought from a guy on here, Arizona Steve I think, are doing a good job. The Allen key ends also make it a lot easier to drain the carbs in situ.
    Faighaigh.
  4. proad
    proad Member
    bartlesville
    ordered a set from "Polock" here on this site.
    thanks. I may have to guess as well.
  5. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Not sure but have you tried taking the float bowls off and put them on a cookie sheet and heat them in the oven?
    BE SURE TO WASH OFF ANY GAS RESEDUE 1st
    Try some penetrant while it's heating it might loosen them!?
  6. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I had this problem with mine and was able to get them out after heating them. I took mine to my laboratory and heated the inside of the bowl where the screw is over a bunsen burner. Then held with oven mitts I was able to break the screws loose. An impact driver is a great tool for these also. I saw one at Auto Zone for $15. Not a bad price.
  7. carsonschaos
    carsonschaos Member
    Southern Illinois
    I went the Easyout and new stainless allens from Arizona Steve.
    And love them. You'll never strip the head out of those.
  8. RickCoMatic
    Use the Impact Method. But, don't fracture a bowl.
    When you get them out ... throw 'em out ... and get the Stainless!
  9. BlueMaxim
    Central Mississippi
    Yea....get the stainless screws form ArizonaSteve. I have them and they are the bomb!!!
  10. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    See my FAQ on the hammer and chisel method. My carb screws were stuck too. It worked perfectly.
