STUPID QUESTION! Need Help
Discussion in 'XJ Modifications' started by rightwinger, May 31, 2009.
  1. rightwinger
    rightwinger New Member
    St. Louis Missouri
    This may sound stupid, but I went to change my oil filter... and I cannot open the plug. I've tried a large pipe wrench, chisel and hammer and some hardended reverse sockets that bite into the head the harder you turn. Nothing. Stuck.
    is it left hand threaded?
    I don't know how old this filter is, or when the last time it was changed. Bt I can't get that thing out.
    Help!!!
  2. rightwinger
    St. Louis Missouri
    Sorry, that is on an 82 Seca 750
  3. wizard
    If it has been over tightened it will be a bitch to get off. Don't shoot the messenger, but you will probably rip the head off the bolt before it loosens. As the bolt is now goosed, use a small cold chisel & hammer on what looks like a washer, but it is part of the bolt. It is not left hand thread.
  4. rightwinger
    St. Louis Missouri
    Thanks, that is what I was afraid of though.
  5. nsosh5
    nsosh5 Member
    oklahoma
    I had to do mine. It wasn't too bad. I used a grinder though. When you buy another bolt buy aftermarket. It has a bigger head on it. Mine measures to a 17mm and I haven't had any problems since. Good luck!!!
  6. rightwinger
    St. Louis Missouri
    You used a grinder to make notches for a cold chisel to grab it...? Good Idea. new bolt.. Better idea.
  7. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Might try giving a pipe wrench a try. It will progressively tighten the harder you push down on the handle. Worst case? You turn the head of the bolt off and now it's easy to get to the shaft of the bolt. Chacal has new ones.
    Loren
  8. bill
    bill Active Member
    Raleigh, NC
    I used the rounded head sockets and an impact wrench - your millage may vary. :)
  9. Libertas
    Libertas New Member
    SL,UT
    I rounded off mine too, what I did was take a smaller socket and taped it on to the bolt with a sledge, then removed with a ratchet.
  10. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    I beat a socket on mine too but then I took it apart and welded a 17mm nut onto it!
    Comes off easy now!
  11. 83xjturbo
    83xjturbo New Member
    i too have had the pleasure of fighting the oil filter bolt. apparently the extra heat produced by a turbo doesnt help with unseizing bolts. :D
    my solution was to use a die grinder to create two large flat spots on the head of the bolt which can then be grabbed firmly with an adjustable wrench. i purchased a new one from bike bandit for around 50 bucks, however, yours may be cheaper. my bike is a seca turbo so it has the check valve in the bolt to keep oil from draining into the turbo after shutoff. i dont think the n/a bikes have anything but a bolt, so it should be a little cheaper.
  12. rightwinger
    St. Louis Missouri
    Good idea. I will try that.
    The thing is on so tight, I was afraid that it might be left handed threds and I was just making it even tighter.
  13. kevineleven
    kevineleven Member
    Columbus, Ohio
    There are no stupid questions, only stupid people.
  14. 83xjturbo
    nope, not left handed, just very tight. another problem you may run into once you ahve it removed is the bolt being stuck to the oil filter housing. i had to put my oil filter housing in a vice and beat the bolt out. I dont know if it was stuck on the o-ring or the housing itself, but my guess is the previous owner installed it with the o-ring dry and the oring seized. make sure you lube the orings prior to install or you may find yourself using a hammer as i did.
