Stupid theives lead to stupid questions
Discussion in 'XJ Modifications' started by Stoopkid22, May 12, 2015.
  1. Stoopkid22
    Stoopkid22 Member
    Virginia
    just like the titles says.....about to ask some stupid questions. My car got broken into a while back and my phone was stolen. I had all the pictures from my bikes tear down on there. So now I'm not completely positive where everything hooks back up. As of right now I need to know 2 things but in the coming days I may be using this thread to ask more and possibly stupider questions. Today I just need to know where the hook ups in the following 2 pictures go to. If you have pictures of yours it would greatly help but if not no big deal. Thanks in advance.
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    In the first picture that heavy wire goes to the starter solenoid beside the battery. Not sure what you are asking in the second picture. These are not stupid questions we are here to help.
  3. razz1969
    razz1969 Active Member
    Cleveland, Tx
    Second pic is ground, one wire to the negative post on battery the other to a grounding point on the frame.
  4. Stoopkid22
    Stoopkid22 Member
    Virginia
    Like this? If so....I'm guessing the other heavy wire is a ground?
  5. Stoopkid22
    Stoopkid22 Member
    Virginia
    Thank you razz
  6. razz1969
    Cleveland, Tx
    The real question is, what are those things on the end of the carbs???:oops:
  7. lostboy
    No that wire goes to the positive terminal on the battery.
  8. razz1969
    Cleveland, Tx
    yes and your welcome
  9. Stoopkid22
    Stoopkid22 Member
    Virginia
    Bike is nowhere close to stock razz....another reason I'm having so many problems and losing those pictures is hurting me so bad.
  10. Stoopkid22
    Stoopkid22 Member
    Virginia
    Thank you lostboy
  11. hogfiddles
    stoop.....don't feel that a question is stupid. If you don't know, you ask----that's why we're here.
    Dave F
  12. BleedingOxide
    BleedingOxide Member
    Brighton UK
    oh shit, that bike looks like fun
  13. Stoopkid22
    Stoopkid22 Member
    Virginia
    Ok guys here's another one. First picture is where it hooks up under the engine and the second is the wire itself. image.jpg image.jpg
  14. Stoopkid22
    Stoopkid22 Member
    Virginia
    Also....the square goes to the igniter unit.....what does the circle plug into? image.jpg
  15. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    That's the [presence of] oil sensor. I don't recall how it routes through, but it eventually connects to the speedo/tach cluster. If'n there ain't no oil, that makes the little red light turn on.
  16. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    I'll check and see where mine is ran when I get home. I think it runs up between that engine cover and the shift/trans cover on the left side and runs under the generator and starter... see that spot where the paint is worn off the engine case where something that ran under the starter rubbed the paint.[​IMG] I think that's were it goes but its been a couple years since I messed with that on mine so i'll have to double check.
  17. Stoopkid22
    Stoopkid22 Member
    Virginia
    It's turning over guys! Thanks so much! I'm probably going to have more questions so I'm going to leave this thread open. Thanks again guys!
