Swapping Vacuum petc0ck for non-vacuum - can it be done?
Discussion in 'XJ Technical Chat' started by mrtim123, Apr 20, 2011.
  1. mrtim123
    mrtim123 Member
    Newcastle, Australia
    Hi guys,
    i've spent the last few hours digging through old pages, but cannot find what im looking for. I found heaps and heaps of info on how to rebuild my vacuum tap though!
    What i want to do is to remove the vacuum petcock entirely and replace it with a standard on/off/res petc0ck. i am fairly sure some model XJ's have these fitted but will they swap straight over and bolt up? What are the models that have a non-vacuum tap?
    Cheers!
    Tim.
  2. SQLGuy
    SQLGuy Well-Known Member
    Re: Swapping Vacuum petcock for non-vacuum - can it be done?
    Something like this would probably work for you: Generic petcock, or a proper non-vacuum XS650 one, but I'm going to ask the question: why?
    The vacuum actuated petcock is a safety feature. It shuts off fuel flow when the engine stops. Are you having that much difficulty getting the stock one to work correctly?
  3. darkfibre
    darkfibre Member
    Perth, Australia
    I bought mine from Len at XJ4Ever (site sponsor)
  4. mrtim123
    mrtim123 Member
    Thanks for the quick replies guys. Yeah, i have always had issues with the leaky tap and its only ever been part of the vacuum assembly that has leaked. On all of my other bikes i turn the tap off when its not in use, so the safety aspect of it is null and void for me - ill just turn this one off too. Just wanted to know which tap it was that would fit.
  5. SQLGuy
    Not quite what I meant about the safety feature. The point is to shut off fuel flow in case of a crash, so that it's not puddling out of the carb overflows after the bike's laid down and the engine's stopped.
    I seem to recall having some problems with the petcock on my XJ when I first bought it. I installed a new one from Yamaha and it gave me no trouble at all for the five years or so I ran it before switching to FI.
    The one on the GPz was sticky (not opening or closing well when vacuum was applied or removed), but after taking it apart and cleaning it with carb cleaner, it's been just fine.
    Cheers,
    Paul
  6. RickCoMatic
    Having the Petcock Vacuum Operated is Insurance.
    But, a lot of those Policies have expired.
    The question is: "Can your Float Valves handle it?"
    If they're the Stock Factory Seat-set; the Float Needles might let you down, soon, and Flood.
    Special Order some Float Valve Pins that are:
    Spring-loaded with Viton Tips.
    Install a Ring near the Ignition Switch. Employ a Key Chain Quick-release Tether. Let freeing your Keys remind you to Shut-Off the Gas.
  7. wizard
    You could always tie a knot in your hankey, Rick.
  8. BillB
    BillB Active Member
    Tulsa Oklahoma
    I switched to the manual petcock. It cost's about $15. I have no problems remembering to shut off the manual petcock after a run.
  9. mrtim123
    mrtim123 Member
    yeah i wont have a problem shutting it off after a ride, i do it on all my other bikes. This is the first bike i have ever had that i could NOT turn the tap to the OFF position, so its always kinda bugged me tbh!
    I just needed to know which normal taps i could use to replace this vacuum powered device :) Looks like the XS650 tap is the go. Is this one a straight bolt up swap or are there some adjustments required?
  10. wizard
    You can use the vac pet **** just block one passage with epoxy putty, I did mine over a year ago, no prob'.
  11. RickCoMatic
    Fitting the Manual Petc0ck to the Yamaha Tank may involve just mounting the new one.
    Installation Methods:
    1. Bolt-on
    2. Adapter Plate and Mount
    3. Resizing the Tank's Petc0ck Mounting Area
    If the Filter Tower is Round; you may need to enlarge the access hole.
    If the Mounting Holes don't line-up; you need an adapter.
    Some people just use a Round Tuit!
    http://kalecoauto.com/index.php?main_pa ... ucts_id=20
  12. BillB
    BillB Active Member
    Tulsa Oklahoma
    This is the actual petcock as it sits on my bike today.
    This one bolts straight up EXCEPT, I had to fab up a rubber gasket which
    was no big deal.
  13. mrtim123
    mrtim123 Member
    Thanks rick, i never thought i would get a round tuit ;)
    as dodgy as it sounds, i was thinking of sealing up the vacuum part with a quick-steel type product. Might just get me riding again this weekend at least :)
