tach cable?
Discussion in 'XJ Technical Chat' started by Xjrider92117, Sep 3, 2016.
  1. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Hello all. So it appears that my tach cable is stuck inside the gauges. When you loose the nut all the way off the cable should just pull right out. Correct? I tried to pull it out a bit but I didn't want to break anything so I thought I'd ask for some advise before I broke something. This is for a 82 max 550.
    Jim
    yes it should just pull out try some penetrating oil just a little
    Xjrider92117 likes this.
  3. Xjrider92117
    San Jose Ca
    Thanks for the reply. Just had to pull a little harder. The end of the cable looks all jacked up. That's probably also why it didnt work. Good thing I've got a spear....
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    That's right, stab it into submission until it behaves proper!
