tachometer/speedo cluster
Discussion in 'XJ Modifications' started by RiceBiker, May 22, 2014.
  1. RiceBiker
    RiceBiker Member
    San Leandro, CA
    Looking to scrap the OEM gauges, broken pointer on speedo and tachometer just plain doesn't work. What's good? What's out there? Do they have an electronic all in one deal? How does that hook up? Saw one @ BaldGuy page. Nice!!!
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    What year? What bike? Mechanical or electrical gauges wanted? How much are you willing to spend?
    Dime City Cycles
    Drag Specialties
    Dakota Digital
    Any cheapie from EBay
  3. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    I see my work here is done. ;)
    Base430 likes this.
  4. hogfiddles
    If you're going to toss your old gauge cluster I might be interested I. It for parts ......
    Dave fox
  5. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    i know I'm tossing a bunch of parts off of mine...but I will be going with a setup from dime city and a matching tach
  6. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    Looks like the same speedo I used for my setup...
  7. Ribo
    Ribo Prefectionist
    and mine in sexy black....
    http://www.dotheton.com/forum/index.php ... 9722;image
    Tried to post it as a linked picture but it never works for me... I wish the underlying website/forum format here was easier. I love the folks here and content but the format is terrible.. you should copy the DTT format.. so much easier... rant over...
  8. Mad_Bohemian
    Ravenna MI
    Upload your pics to photobucket or a similar photo hosting site, easy-peasy posting links from there.. just like I did with my above pic :D
  9. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Did you have any trouble with the idiot lights on that speedo? I had one on a Sportster which gave me fits. I could only ever get the turn signal indicator to work on the left side, although the signals worked on both sides. If I hooked both sides to the light, the signals on both sides would flash together.
    Oh, and after 20000 miles the needle would dance all over the place.
  10. Ribo
    Ribo Prefectionist
    Problem is it doesn't work from photosites that mask the image syntax.. :( hey hum.. not trying to derail the OP's post... ignore me..
  11. Ribo
    Ribo Prefectionist
    Yeah, there's a lot been said about that on other post.. check out my post on DTT that talks about adding diodes to each side of the turn signals before you connect them to the speedo turn light wire... also the high-beem light is ridiculously bring even when it's not "on". All the lights get some bleed illumination from the back-light but it's obvious when they are off/on - not so much with the blue one.. I'm living with it now but I am going to put a resistor inline - much like the diodes - that should dull it down.
    http://www.dotheton.com/forum/index.php ... #msg681188
    Also you have to install them with some kind of vibration protection, i.e. rubber washers, so the internal coils don't loose their tension - this is what causes the needle bouncing.. This can be tricky to do with the single bracket hole. people have fabricated brackets - I put a bolt together with some spring washers and rubber boots that works for now.
  12. ChrisRomello
    ChrisRomello Member
    PSJ, Florida
    I'm still shopping but I think I might go with this:http://www.ebay.com/itm/400633392612
  13. myasylum
    myasylum Member
    Grafton, WI
    That is a interesting one! I've been looking myself. Haven t seen that one yet!
    I wonder if we could get the fuel gauge to actually work?!?
  14. Polock
    i've been thinking (dangerous) on the turn signal indicator dash light.
    if you can see the back of your signals it wouldn't be hard to put a single led on the back, top, side, that you could see and it would blink with the signal. make it any color you want, be the first one on your block....
  15. cg82
    cg82 Member
    Rossland British Columbia
    Gonna revive this! Doesn't adding resistors create quite a bit of heat? Where physically are they located?
  16. Ribo
    Ribo Prefectionist
    current causes heat in a resistor - or more accurately the displacement of current. The level of current that we're dealing with here is so low the heat generated is minimal. Obviously you gotta have the right size resistor but once it's wrapped in tape it's not noticeable at all. You can put it wherever you like really. I'd say it's about 1/1000th of the heat coming off the engine.
  17. Orange-n-Black
    Memphis Area
    I used a similar speedo(like the one Mad Bohemian showed), then replaced the idiot light bulbs with different colored leds from the auto parts store. They worked fine.
  18. BaldWonder
    Oberlin, OH
    I double-checked my Amazon link to the speedo I used, the Acewell 2853, and it would seem it's dead now. So here's the same thing on ebay http://www.ebay.com/itm/Acewell-285..._DefaultDomain_15&hash=item45fbbff2c0&vxp=mtr
    Note that this is not the cheapest listing, but it has better pictures. It's also available in chrome. I don't yet know if the 750 fuel sender works with it, but when I find out later this year, I'll post back.
  19. k-moe
    That depends on what the resistor is hooked to, and what it are being used for. For example, the ceramic resistors that are typicaly used as dummy loads when fitting LED signals will get hot enough to burn your hand, or to melt plastic bodywork.
  20. BaldWonder
    Oberlin, OH
    I know this is way late, but I only just now looked back to see this. Hank, the turn signal indicator in our clusters are only wired as absolute indicators, i.e. it flashes whether its the left or the right. When I wired mine up, I ignored that wire entirely and instead fed directly from each turn signal; the green and brown wires if I remember correctly.
  21. hogfiddles
    don't you have to have one-way diodes there, too? Otherwise, wouldn't the current feed back to the the other light?
    Dave
  22. k-moe
    Enough resistance at the dash bulb will prevent the bleedthrough from being enough to activate the other turn signal (this is what prevents the stock bulbs from activating via bleed-through voltage; the indicator bulb causes enough votage drop that the opposing signal bulb can't light up). Diodes are the more elegant (and electricaly efficient) solution.
  23. BaldWonder
    Oberlin, OH
    Where's the shrugging emoticon when you need it? o_O
    I honestly don't know, Dave. I just connected it and it worked. As far as I can tell the left and right signal indicators on my unit are totally separate. They just share a single ground is all.
  24. Ribo
    Ribo Prefectionist
    yeah I was talking in reference to this specific use case.
    Secondly - when I installed this tack with turn-light instrument bulb on my xj the wire to the instrument panel was a single wire from both sides - so moe is right - then original design didn't have diodes due to 1980's bulbs displacing all the current. if you install LED's you need diodes else both sides will flash no matter which way you turn. If it doesn't for you Mr Wonder there must be something gating this or maybe a frame ground in just the right place somewhere.
