Tail Light/Park Light not working...
Discussion in 'XJ Technical Chat' started by Alive, Jul 21, 2007.
  1. Alive
    Alive Active Member
    Queensland, Australia
    It looks like it's getting no power... I have power at the switch, all other lights work.
    I've done a little playing around and I have no idea why the front park and tail light are not working.
    I'm thinking of pulling the ignition apart to see if the problem is there.
    Any other things I should look at?
    Oh and definately not the bulbs, they work fine when I hotwire them.
    Cheers
  2. Maximator
    Maximator Member
    South Cariboo, B.C., Canada
    What do you mean by the front "park" light?
    Assuming your headlight and dash lights are working it's not the relay that triggers the lighting system after the motor starts. That was the culprit with my light system.
    I'd be tracing the wiring from the tail light and checking for power at each connection as well as cleaning up the connections. This should let you find where the problem is.
  3. Alive
    Alive Active Member
    Front park is th small bulb in the headlight... Dash and headlight are fine.
    I have cleaned a few connections and traced some of the wiring... Guess the only thing to do is go over it again :)
  4. ridz
    ridz Member
    Ride hard and live free!
    I would say you are on the right track, cuz I had the same problemand I put a new ignition switch in and problem solved...good luck with it....Ridz
  5. Alive
    Alive Active Member
    I've got another ignition.... I'll plug her in and findout :)
  6. Alive
    Alive Active Member
    Yup it was the ignition.... Cheers
  7. ridz
    ridz Member
    Good stuff there alive, now get your knees in the breeze :lol:
  8. Alive
    Alive Active Member
    Oh boy have I been doing that 8)
  9. Alive
    Alive Active Member
    Oh and for those who are interested... Pulled the ignition off, found a broken wire, soldered it back on and off I went ;)
