Tank Alternatives for an XJ650RJ Seca?
Discussion in 'XJ Modifications' started by MinutemanMedic, Aug 15, 2015.
  1. MinutemanMedic
    MinutemanMedic New Member
    Kansas
    According to the parts catalog post, I should be able to use a 650Maxim or 750 Seca/Maxim tank in place of my dented up 650Seca tank, correct? I just can't seem to find another 650 Seca tank anymore. :(
    From the other post:
    (NOTE on tank interchange: all XJ650 (except Turbo) and 1981-83 XJ750 (except XJ750RL) tanks will swap between those models and fit, but may experience some minor interference issues with the front of the seat/seat pans. Many XJ650 Maxim and Midnight Maxim owners like to upgrade to the larger XJ750 Maxim tanks, and that is basically a bolt-on swap.)
  2. hogfiddles
    What's wrong with your tank?
  3. MinutemanMedic
    Kansas
    I have two tanks now that have big dents on the left side. Not easy ones to pull out or I'd go that route.
  4. hogfiddles
    Chances are that any tank someone has left is probably rusty, my extra one included, too. Pull the dents, use one and sell the other.
    Run likes this.
  5. k-moe
    Post up a pic and one of us might be able to give you a plan for getting the dents out (or out enough that minor body work will make it look good).
  6. MinutemanMedic
    Kansas
    Here's the current dent.
  7. hogfiddles
    Heh...... Obviously not the first time it's gotten bashed in
  8. MinutemanMedic
    Kansas
    First time from me. It was a used tank when I bought it a while back. The original tank has a dent almost exactly like that one. Don't have a picture available currently. Think it could be pulled out or should I opt for another tank, a 650/750 Maxim tank possibly?
  9. george2524
    george2524 Member
    Maryland, USA
    If you want to look at the lighter side of dent pulling check out Ichiban Moto on youtube - this guy is hysterical. But do check out some of the serious videos on dent pulling on youtube.
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Seriously? He called that tiny tank a Goldwing tank? Also, where do you find metric vice-grips? Hilarious.
  11. k-moe
    Ichiban is a hoot. He does that very much on purpose.
  12. MattiThundrrr
    Betcha a Goldwing has more oil than that tank can hold.
  13. Dave in Ireland
    Ireland
    Whatever you do, don't try to blow out the dent by filling the tank with compressed air.
    A friend tried that, and ended up with what he described as, "an amusingly-shaped potato". Unless you actually want a spud tank, of course.
  14. zap2504
    zap2504 Member
    Middletown, PA
    The 650 Seca tanks are pretty rare (in the USA - only here 1 year) so I'd say to take it to a real good body shop. They will likely cut off the bottom, re-shape the tank and re-weld the bottom back on. Not cheap, but the results will be stellar, and that bike/tank look so good stock.
