Tank questions
Discussion in 'XJ Technical Chat' started by mmcgee, Jan 27, 2013.
  1. mmcgee
    mmcgee Member
    While I'm waiting on my new petc0ck. I thought I'd tackle a few cosmetic issues.
    -Anybody have a clever way to pop two dents out of a tank?
    -There is some debris in the tank. what's the best method to flush it?
    -The front pipes/manifolds are rusty. Is spray on chrome a waste of time? Some folks have blacked the pipes. Anybody else done anything creative?
  2. adrian1
    adrian1 Active Member
    What sort of Debris is it? Rust? If so, flush with petrol, then search on electrolysis
  3. maximike
    maximike Member
    Portland, OR, USA
    Spray on chrome? You mean chrome colored spray paint? That won't work on header pipes, too hot. Even if there's some kind of high heat version, it won't look very good, in my opinion. You may be able to do something with them, paint black, or you could use that exhaust wrap stuff. You know, the tape? Some guys like the way that looks, wrapping the headers in that.
    I "flushed" my tank with water, a bunch of wood screws to scrape off rust, and phosphoric acid, sold as concrete etcher at Home Depot.
    As for dents, there's a lot of techniques, how big of dents? Bondo might be easiest. Or you can rent a welder and use those dent pulling rivet things. Check on youtube, I've seen a lot of videos with body work tips on there.
  4. mmcgee
    mmcgee Member
    The debris is just metal chips and dirt. nothing appears rusty. I'm going to flush it with gas.
    The dents are big. About 4x3 in. and 2x3in. Not very deep or creased though, so I think there is hope.
  5. mtnbikecrazy55
    Chrome paint looks like crap, especially on something that would get as hot as headers do. If I were you I'd just paint ten black or wrap them until you can find another set of headers to swap out.
  6. Madmusk
    Madmusk Member
    Albany, NY
    I plan on trying out some of the techniques outlined in this video for the dent in my tank.
  7. mmcgee
    mmcgee Member
    Yeah I tried everything but the blood pressure cuff. No luck.
  8. mmcgee
    mmcgee Member
  9. hogfiddles
    If your tank isn't rusty inside and you just want to get some loose stuff out, pull the tank, drain it, let it dry out a few days til it's good and dry inside, shake everything down into the front right corner, now stick a vacuum cleaner extension down in there and just suck it out. Works like a charm.
    Dave F
  10. mmcgee
    mmcgee Member
    Ah. So simple. Thx hogfiddles.
