Tanks
Discussion in 'XJ Modifications' started by 82madmax, Apr 8, 2016.
  1. 82madmax
    82madmax New Member
    SFSD
    i have a 82 xj750 with the 1100 power plant. Tank on it currently is off the xj550 but has a small pin leak currently sealed with quiksteel. Does anyone know if XS tanks would bolt up as well?
    if it is a pin leak why not just have it soldered?
    what mods to the mounting system did you do to fit a 550 to a 750 frame?
  3. 82madmax
    82madmax New Member
    SFSD
    I bought it this way actually tank was all dented up and had rust inside. We cleaned it up as much as possible but the rust remover ate a little hole in it. My buddy decided to try and tack a weld and blew a big hole in it. I don't know what modifications they had to do if any i do know the 550 doesn't have a fuel guage connection on the tank so honestly I'm assuming it's a 550 tank
  4. hogfiddles
    The 650 maxim tank is a direct bolt-on interchange with the 750 maxim tank. The 550 maxim tank LOOKS about the same but the measurements between the rear mount and the rubber bushing guides are different. I doubt that it's a 550 maxim tank, unless someone relocated some things---- which HAS been done.... I've seen it done---
  5. XJ550H
    550 tank data
    maxim from front edge of rear tank mount to rear of front tank mount 450mm 1' 6-7/16
    seca from front edge of rear tank mount to rear of front tank mount 496mm 1' 7-9/16"
  6. hogfiddles
    I did some write-ups on tank comparisons awhile back..... Do a search and you can find the info
  7. 82madmax
    82madmax New Member
    SFSD
    Thanks hogfiddles I wasn't sure exactly
