TCI questions...
Discussion in 'XJ Technical Chat' started by Rod1, Aug 21, 2016.
  1. Rod1
    Rod1 Member
    San Luis, Argentina
    Hi guys, again it's me... I started this because looking for a problem in my carbs and valves I realized that my TCI unit can go faulty. I read a lot in the last day about this TCI and how it's work. I know that switching TCI's can have an influence in the advance of the engine making run but not as it's expected to run. So, Can any one tell me what model of TCI should be on my 1985 XJ 700N?? This is a pic of what I got now. Someone opened and I'm suspecting that was replaced for any other model... 20160820_140514.jpg
  2. MiGhost
    MiGhost Well-Known Member
    Looking through the ignition section of the parts catalog. It shows the TID14-44 is the correct TCI for your bike.
    ~Ghost
  3. a100man
    a100man Well-Known Member
    Bedford, UK
    TCI number should match number on pick-ups also..
  4. Rod1
    Rod1 Member
    San Luis, Argentina
    Well at least seems to be the right one!!...thanks guys
  5. Polock
    if you happen to find one for a different bike at a good price it might be a good idea to get it for a spare. i think any of them will run the bike but maybe at lower performance.
    that would be better than no bike at all until you can get the right one
  6. Rod1
    Rod1 Member
    San Luis, Argentina
    there is one company here that make the tci for only this bike, model and year...just my luck..its not cheap but at least there is one...
  7. Rod1
    Rod1 Member
    San Luis, Argentina
    Since I had problems with the starter motor I didn't have time to try the bike in a long ride to check how the bike react when the TCI heats up...anyway I don't even know if TCI's heats up...since I cleaned the contacts the bike was reacting 95% better than before when I ride around town at least... Someone know if TCI's heats up??
  8. k-moe
    The TCI won't heat up any more than a transistor radio will, but any temperature increase can cause bad circuit boart traces, or solder joints to lose continuity as the board expands and flexes.
  9. Rod1
    Rod1 Member
    San Luis, Argentina
    Right. I didn't have the time or will to open it because I want to ride... But I noticed when the bike was running for a time the sputtering between 500 and 2000 rpm's still come back...
