testing coils off the bike
Discussion in 'XJ Technical Chat' started by littlejohn, May 23, 2011.
  1. littlejohn
    littlejohn Member
    Barrow County, Georgia
    I've got the coils off the bike and need to find out if they're good or not before I sell them. How can I do this?
    I can only get an ohm reading at the connectors. I don't really know where to go from there.
  2. wizard
    test the 2 thin wires, should be 2.5 ohms.
    test the 2 HT leads, should be 11K ohms.
  3. SQLGuy
    SQLGuy Well-Known Member
    That's 11K Ohms with the caps removed... just measuring between the two wires.
  4. littlejohn
    littlejohn Member
    I'm getting 3.43-3.5 ohms at the connectors and 13k-19k across the plug boots but across the plugs it pops up the number real quick and then displays 0.
    Does that sound right?
  5. wizard
    Yes, if your running 'R' caps.
  6. SQLGuy
    Cross your leads and see what that reads, then subtract that from the 3.5 ish readings to get a more accurate primary side value. Probably OK.
    13K to 19K is quite a range. Check them without the the caps. They should be pretty close to 11K. Check the caps as well and at least make sure that the 1/4 caps match each other and that the 2/3 caps match each other. Probably all four should match, since the resistance value controls the burn time and there's no reason I know of to have different burn times on different cylinders.
  7. littlejohn
    littlejohn Member
    I have no idea what you're talking about with the caps. This is what I'm dealing with.
    You can click it to make it bigger.
  8. SQLGuy
    Yup. Those caps are screwed on the wires. They're also called spark plug boots, if you prefer.
    1. Pull back the rubber seal that covers the point where the wire enters the cap.
    2. Hold the wire firmly near the end of the cap and unscrew the cap from the wire (CCW).
    3. Do the same to the other wire's cap.
    4. Measure resistance through each of the caps (should match), and from one wire to the other wire (should be about 11K).
