Testing for leaky enrichment circuit ?
Discussion in 'XJ Technical Chat' started by khblue, May 20, 2008.
  1. khblue
    khblue Member
    The fuel levels are the same on all four and one is running really rich, even with idle screw fully in.
    I've
    - cleaned the removable air jet and poke the unremovable (Mikuni) idle air jet. Blown air through both with a cycle pump and air matress adapter !
    Is there an option other than a leaky enrichment valve ? Should I try and drop the fuel level anyway and hope that compensates ?
    If that's the most likely how do I check for that ? (On my Mikuni's I can't remove the enrichment plunger because they are all in line.)
    Ta
