The beginning of the end.....1983 XJ750 Maxim
Discussion in 'XJ Modifications' started by Dusti, Mar 17, 2015.
  1. Dusti
    Dusti New Member
    Jacksonville, NC USA
    This is my first bike ever, I've ridden dirt bikes and mini bikes in my life, but never had a motorcycle. I want to get this beast on the road and going. Would like to know where I should start. Any and all help would be appreciated.
  2. Dusti
    Dusti New Member
    More pictures of the bike.
  3. Dusti
    Dusti New Member
    Even more pictures.
  4. Joris
    Joris Member
    Eindhoven, NL
    Looks to me that you have all the important bits.
    What I woud do is:
    * decide if you want to rebuild stock or custom
    Assuming you go for stock, then
    * get at least one service manual
    * rebuild the Rolling frame: repair rust and damage, front and rear brakes, wheel bearings, stearing bearing, clean all connectors on the wiring harnass
    * mount starter motor (photo 5 top left) to engine, change oil and perform compression test
    * rebuild engine if needed
    * rebuild carbs
    * install airbox, engine and carbs
    * clean and install all the parts that you have left
    * changes the tires
    * start the engine and enjoy the ride
  5. FtUp
    FtUp Well-Known Member
    pacific northwest
    welcome to the forum. before I spent any money on any of it, I would do the compression test. if the engine is junk, then it would be cheaper to find a running replacement.
    FU
  6. JaiFer
    JaiFer Member
    Northern Ontario
    Welcome. Was this bike running when you bought it or did come in the basket? Does the engine turn over or is it seized? Having a running engine would be the first start, any other parts, I would wait. Tearing down an engine can be a daunting task if it's your first time. You may want a mentor or a buddies help.
  7. k-moe
  8. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Wow, K-moe... you make it seem effortless! Wanna fix mine in five easy steps for me? Also, what's Step 3?
    As for Dusti, welcome to the group. Apparently those Midnight Maxims are a bit more rare than the average XJ. Good luck with your build!
  9. chacal
    Not just an 83 XJ750 Maxim, but a MIDNIGHT Maxim, at that.
  10. k-moe
    I don't usually mention step 3. Nobody enjoys step 3. ;)
  11. MattiThundrrr
    That must be where all the real work is hiding.:eek:
  12. Dusti
    Dusti New Member
    The bike was as pictured when it was "given" to me. I've got a few guys at work that are good with motors and things of that nature. One rebuilds classic cars and the other is a tuner head. But I think between the two of them and all of you gents I'll be fine. I took the carbs off of the motor and it seems that they are in desperate need of some T.L.C., so I'm in the process of doing that. Does anyone have any recommendations on a good rebuild kit for those.
  13. MattiThundrrr
    Check out Chacal. He's a member here. Runs the shop advertised in top corner
  14. Dusti
    Dusti New Member
    Progress.....
  15. k-moe
    One bit of advice; don't dip the carb bodies. The throttle shaft seals will not survive (thought they probably need to be changed anyway by the looks of the rest of the carbs condition.
  16. Dusti
    Dusti New Member
    More progress.
  17. Dusti
    Dusti New Member
    Does anyone have the service manual for my bike in pdf format that I can get?
