The horn mystery
Discussion in 'XJ Technical Chat' started by pkay, Mar 24, 2013.
  1. pkay
    pkay Member
    Brisbane, Australia
    Well it is to me.
    Should my 1981 XJ750 have one horn or two? I have two horns in my possesion that aren't the flat type but have the scooped entrance (not a great description I know). Some areas suggest that there was a hi and low tone horn wheres Haynes is not very helpful at all.
    Could the learned please suggest what is correct. I do like the idea of the twin horns so I guess if the wiring loom has the connections for two that would be the way to go..
  2. 750E-II_29Rbloke
    South Cheshire, UK
    Wiring diagram for 750RH shows 2 horns, says they're smaller than usual and mounted *inside* the headlamp nacelle :? I'd guess after this amount of years the wiring could have been hacked but you never know. The horns can just be wired together in parallel (power & earth to first horn, extra wires to take power/earth from first to second) if there's only wiring for one, that's how the diag. shows them
  3. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    All 4 of mine had 2 horns . two xj750 rh 1981 and two xj750 rj 1982
  4. pkay
    pkay Member
    Brisbane, Australia
    Interstingly enough when I looked at the two horns in the box that came with the bike they are definitely left and right side horns.
    Two it is then!!
