The most sinfull carbs
Discussion in 'XJ Technical Chat' started by ecologito, Aug 15, 2013.
  1. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    So most people here know about having a bike in grast running conditions. To achieve that at some point you have to attend the "church of clean".
    What are the most sinfull and filty carbs you have ever seen? I am getting ready to clean my second set of carbs and break a rack for the first time (full exorcism on these puppies).
    This rack came off the 650 seca that I bought for parts. It had pods so I figured PO caredabout th bike and fiddled with it. Well, who knows but the carbs are nasty and jets are stripped. I was not able to get one off, i'm still working on it.
    This rack was so bad that bot even kroil would loosen up the float needle seats, I had to bring an impact drive to get the suckers loose.
    On the bright side evetything else is coming apart nicely with my handy can of Kroil and a new set of JIS screwdrivers.
    Pictures will be up soon.
    Share your pictures of the filthiest most sinful carbs yu have encountered.
  2. ecologito
    NASCAR Country, NC
  3. mlew
    mlew Well-Known Member
    Apex, NC
    Those are nasty but I have seen worse.
    With jets messed up like that its a good idea to replace them.
  4. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    wow, those are bad.....BATH TIME
  5. maverickbr77
    maverickbr77 Member
    Lowville, New York
    I pushed the slid up in this guy to see how they moved and it stayed up. The jets weren't buggered up though.
  6. Polock
    Yea, those are dirty but not too bad. You'll have some nice spares when your done
  7. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    Mom! Eco's giving me nightmares again!
  8. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    One of the racks I worked on, I had to soak before I could get the pistons out...
  9. RickCoMatic
    I serviced a rack that sat for 15-years.
    The Fuel Bowls looked-like the Road-gang from "Cool Hand Luke" tarred them twice.
    The Diaphragm Piston Needles were stuck inside the Nozzles.
    I had to Boil the Rack to get the Pistons out.
    But the Carbs are light-alloy, brass and bronze.
    They clean-up good no matter how filthy.
    Here's a look at what I found when I pulled the Main Jets:
