the wifes xmas present
Discussion in 'XJ Technical Chat' started by FtUp, Dec 27, 2013.
  1. FtUp
    FtUp Well-Known Member
    pacific northwest
  2. Fuller56
    Fuller56 Well-Known Member
    Very Cool! And it took you 2 days to post this event because it took that long to build up the strength to crawl to the computer because of how completely and effusively she said "thank You"? Congrats to both of you
  3. RonWagner
    RonWagner Member
    That's awsome, I don't know her interest level but be careful not to expect her to go on as many or as long of rides; you don't want her to get discurraged. My wife has a XJ650 and enjoys riding but only for a half hour at a time. Me, I could ride all day and ride again the next day.
  4. z32800
    z32800 Member
    Wellington New Zealand
  5. patmac6075
    patmac6075 Active Member
    MKE
    SCHWEET! :D
  6. Keith30
    Keith30 Member
    MI
    Very nice
  7. FtUp
    pacific northwest
    thanks guys. today we got the first of what will be many bundles of joy to grace our mailbox.
    bundle of joy
    by bmonkey36, on Flickr
    and it appears that the bike has two left pegs...
    left peg
    FU
  8. Keith30
    Keith30 Member
    MI
    Sweet, where'd ya get those brake shoes?
  9. FtUp
    pacific northwest
    the bay of e of course...
    FU
  10. FtUp
    pacific northwest
  11. FtUp
    pacific northwest
    I just discovered that I have a custom cold start cable clamp. can anyone recognize the source?
    cable clamp
    FU
  12. FtUp
    pacific northwest
  13. xHondaHack
    Orange CT
    It's always fun going through a newly acquired bike to sort out all the butchering and crap that previous owners did (or didn't do) to them.
    BTW, the cable clamp is the screw on connector for the top of a spark plug.
    I'd say you need a new cable.
    Tony
  14. FtUp
    pacific northwest
    we have a winner! yes that is not the first time I have seen one of those converted into a cable clamp. I used to repair Volkswagen beetles for a living. the heater cables were a common place to find them.
    FU
  15. bigfitz52
    TIP*** You can move the airbox rearward quite a bit to make carb installation even easier.
    The top mounting screws are in slotted brackets up by the rear of the tank, those are obvious.
    There is a third screw located under the tool tray. Remove the tool tray screw, lift the tray up, and then you can remove the upper rear airbox mounting screw.
    Here's a tore apart Mikuni: http://xjbikes.com/Forums/viewtopic/t=31061.html
    FtUp likes this.
  16. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Im jealous. Fiance only rides on the maxim x very seldomly and wont touch the vmax. I guess just gives me alone time.
  17. FtUp
    pacific northwest
    something I have noticed about theses mikuni carbs is the float pivot pin binds in the float pivot. this can cause all kinds of problems since the pins are an interference fit in the carb bodies.
    FU
  18. bigfitz52
    That's one of the things you need to be aware of and correct when rebuilding Mikunis. It means either the pin itself is ever so slightly bent; or the wrapped-metal bracket on the float needs its bore cleaned or maybe some gentle tweakage.
  19. Polock
    would have been a lot easier to get her a nice new toaster :)
    Hotcakesman likes this.
  20. FtUp
    pacific northwest
    you know it!
    FU
  21. k-moe
  22. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    I am so glad this bike found a home .i have been watching this bike on craigslist for some time thinking of buying if for my wife but she did not like it . Nice job he almost gave up on selling it i think by the way he kept changing the add to make offer . congrats on the new bike !!
    FtUp likes this.
  23. ElkHavenSeca
    Sedro woolley wa
  24. FtUp
    pacific northwest
    actually It just occurred to me, we don't own a toaster.
    FU
  25. FtUp
    pacific northwest
    you know, the ad is still up. I am guessing he doesn't get much response and doesn't know how to delete it.
    FU
  26. FtUp
    pacific northwest
    I chucked them up in a drill and hit them with some 220 grit. they work much better now.
    FU
  27. bigfitz52
    Next time use Scotchbrite or 800-grit.
    The Fitz doesn't use sandpaper in carbs, period. (No need.)
  28. FtUp
    pacific northwest
    it is what was closest at hand at the time. it was fine enough to suffice and course enough to make short work of it.
    FU
  29. Polock
    you should really get a toaster, they take PB&J to a whole new level :)
    jmilliken likes this.
  30. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    With bananas :D
  31. FtUp
    pacific northwest
    i am finally getting something done on this bike. I have the carbs reinstalled and the new (used) head pipes installed. too bad the new battery turned out to be junk. so I put the battery from my 750 in it upside down and backwards just to try it. after a bit of cranking, it fired up and ran fairly well. obviously it needs some fine tuning, but I am happy with how it runs.
    FU
  32. xHondaHack
    Orange CT
    Nice to see it up and running.
  33. FtUp
    pacific northwest
    so the to do list has diminished to only a few "must do" items.
    1) rebuild the brake master cylinder and replace the brake lines
    2) sync and color tune the carbs
    3) make the horns work
    so far I have completed the carb rebuild, adjusted the valves, new intake rubbers, replaced the clutch, the rear brakes, new tires, new oil and filter, new air filter, new battery, replaced the head pipes, new shift lever rubber, new clutch cable. new choke cable, new chain and sprockets, new wheel bearings.
    other things I have planned;
    1) install headlight and brake light modulators
    2) do the led turn signal mod
    3) remove all the red and make it all black and possibly do some vinyl wrap graphics
    4) replace the fuse box
    5) rebuild the front forks
    6) install all balls roller bearings in the head ( there is a detent feeling in the steering . very slight but there. it can only be felt when the front wheel is off the ground)
    7) install new tachometer drive gear seal ( it doesn't leak bad but it does leak)
    fortunately the electrical system is solid and completely functional. so it is not an immediate issue.
    FU
  34. FtUp
    pacific northwest
    I got to ride it around a bit today and discovered it has a bit of a wobble around 35-40ish mph, it goes away at freeway speeds and above (tee hee), I am wondering if anyone here has any insight into the wobble. it is very slight, almost unnoticeable. when I had the front wheel off, I noticed that the head bearings have a detent warn into the races. could that be it? it too is very slight, I could only feel it with the front wheel removed. both of the wheels have new wheel bearings and were balanced on a new spin balancer.
    FU
  35. MiGhost
    MiGhost Well-Known Member
    It is time to replace those steering bearings.
  36. FtUp
    pacific northwest
    I ordered a set last night.
    FU
  37. FtUp
    pacific northwest
    well I haven't installed the new head bearings yet, (I have a spare triple tree I want to powder coat first) but I just put a new set of bar end mirrors on. now I can see something other than my arms in the mirrors.
    FU
  38. FtUp
    pacific northwest
    finally had to replace the fuse box with the one I bought from len...
    I also installed an "air blade" mostly for looks...
    FU
  39. FtUp
    pacific northwest
    my oil temp guage arrived today!
    FU
  40. FtUp
    pacific northwest
    I have been getting little bits done here and there. like replacing the side cover grommets before I lose a cover on the road.
    I also reinforced the grommet seating areas on the side covers with fiberglass.
    I am also refinishing the new/used replacement tail piece. the original was broken in several places. pics of it to come once it's painted. I also discovered some heavy rust on one of the seat hinges, so they are getting refinished as well.
    FU
  41. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Sorry to side-track the thread here, but what is that purple leopard print cruiser next to your moto sikkle? Is that paint? It looks like fabric wrapped around the frame tubes and fenders! Yeah, I'm a sucker for anything on two wheels.
  42. FtUp
    pacific northwest
    that's "kitty bike" it was my wife's playa bike for burning man. it is wrapped in fabric. I will get a pic of it up later for your viewing pleasure.
    FU
  43. FtUp
    pacific northwest
    as promised, here is the pic of kitty bike. if there is anyone in the seattle area that needs a playa bike, this one can be had for the low low price of "come get it".
    FU
  44. MattiThundrrr
    Any one know how to get that fabric onto my motorbike?:p Matti likes! lol
  45. FtUp
    pacific northwest
    spray adhesive.
    FU
  46. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Cyclenoob, I love the oil temp guage. I know that they make them for my CB750, but did not know they were made for our XJ's. Where did you pick yours up if I may ask?
  47. Rooster53
    I was curious about the oil temp gauge also. I didn't think you could install one in the oil filler on the XJ as the clutch was in the way, and you could not submerge the sensor in oil, which seems it would not give an accurate reading. So, how long is the sensor on that particular gauge? Do you think it will be accurate?
  48. FtUp
    pacific northwest
  49. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Looks like it's only in Celsius, but I'd totally learn metric to have that little accessory lol.
  50. FtUp
    pacific northwest
    the one I bought is the one linked above, and it was in fahrenheit.
    FU
