Time ran OUT on my XJ650
Discussion in 'XJ Technical Chat' started by ck0724, May 17, 2012.
  1. ck0724
    ck0724 New Member
    Well, after alot of hard work and finally getting everything vacuumed synced, valve shims correct, carbs cleaned, Electronic Tach wired in....... THE CHAIN GUIDE has jammed up my tranny
    Im not one to half ass it and just pull the pieces so ive already started to prepare to pull the engine..... MY QUESTION,
    Before i start searching Ebay and Craigslist, Anyone have a 750 NON YICS engine for sale?
    It will be going in an 81 XJ650 frame.... Thanks in advance
  2. TIMEtoRIDE
    I did no such thing ! . . . :lol:
    You could fish the pieces out and keep riding for a while, until you get your replacement motor organized,
    All 750 motors are YICS, which is pretty irrelevant.
    The Maxim will give you taller gearing than the Seca motor.
    You will need to re-jet the carbs, or use the 750 carbs.
    There's a few other minor details, covered in Chacal's info.
    Good luck - use a compression gauge while shopping for a motor.
  3. bigfitz52
    I thought Maxims were geared lower, for "Boulevard" work, and Secas had the taller gearing for on the highway.
  4. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I run just under 4k doing 80 km/h in 5th if that helps.
  5. TIMEtoRIDE
    As-is, I thought they were about equal, however, cko724 is building a Maxim 650 with a 16 inch rim and if he uses a Seca motor, that's supposed to have an 18' rim it will be geared too low (by about 8%).
  6. ck0724
    ck0724 New Member
    yea, im still looking for a good 750 engine......
