Tire Pressure Question
Discussion in 'XJ Technical Chat' started by hbennick, May 23, 2010.
  1. hbennick
    hbennick Member
    SO, I have an 82 Yamaha xs400r Seca. The manual says tire pressure should be 26/28lbs for less than 198lbs load, and 28/36lbs for 198-474lbs and 2 up riding. The tires say 41 lbs for 2 up riding. I'm about 185lbs, so I split the difference and put in about 32/34.
    Is there a rule of thumb for this? Follow the manual, or follow the tires?
  2. MiCarl
    If the tire manufacturer has a recommendation (and I don't mean the maximum pressure listed on the sidewall) go with their recommendation. They know way more about the tire than Yamaha did 25+ years ago.
  3. bigfitz52
    The 41lbs is the max load inflation. I wouldn't run at 41lbs.
    You're fine at 28/34, might want to go to 28/36, especially for 2-up.
