To those who know about the second gear skipping on xj's
Discussion in 'XJ Technical Chat' started by schooter, Jan 26, 2009.
  1. schooter
    My bike, as most of you know, skips in second gear.... could you tell me exactly what is wrong? and exactly what needs to be done.... im ging to take my bike to the dealer and have them fix it.... sigh, just gotta sell my husqvarna...
    but ya, id like to know exactly what to tell them, cuz when i called them, they didn't know nothing about that.... they just said, "thats strange"
  2. crewwolfy
    crewwolfy Member
    Chicago, IL, USA
    I'm also interested. I'm a few steps from splitting the case to replace the chain guide. If I can, I'd like to solve this issue while I'm in there.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Skips in Second or Pops Out Of Second??
  4. crewwolfy
    crewwolfy Member
    Chicago, IL, USA
    Mine pops out of second into neutral. If I'm on it at the time, it may even pop into first.
  5. stereomind
    stereomind Active Member
    Tulsa, OK
    I've never had this problem myself, but my amazing Search-Fu(tm) reveals that it's usually one of these things --
    Cannot engage gears: Bits of plastic that fall off the HyVo chain guide and get lodged in various parts of the transmission, e.g. the channels of the shift drum. Sometimes those bits can be fished out without splitting the cases -- see "emergency guidectomy" ..this is a temporary fix, as it's possible that the guide will shed more bits of plastic. best course of action is to replace the guide and get all the bits out.
    Gears popping out: Shift forks can be worn or bent... they can be straightened out if bent, but... once you bend a piece of hardened steel, it will lose some of its strength. best thing to do is to replace the damaged shift fork(s).
    Also, Gear dogs can get worn/rounded off. sometimes it's possible to re-surface them with a dremel, sometimes you just have to replace the gears. here's a very detailed walkthrough of a similar operation on an XS1100, just so you can get an idea of what's involved. It's by no means a walkthrough for the smaller XJs. XS11 tranny fix
    I probably missed something, but it's a start...
  6. bill
    bill Active Member
    Raleigh, NC
    :lol: ROFL -
  7. bigfitz52
    Bottom line Schooter; motor has to come out, be flipped upside down and the cases split. Once apart, the extent of the damage and the parts needed can be determined. It could be the chain tensioner is disintegrating, it could also be that AND gearbox issues, bent fork(s) or worn dogs or both.
    If you plan to pay someone to fix it, it's gonna be expensive.
  8. schooter
    i know...
    it doesnt pop out of second.... it skips after 4500 rpm....
    on alot fo the xj1100's peole say you can go through second gear if your gental o nthe powerband... well i never though about trying that.... cuz it locked up on me once... kinda, i couldnt shift... untill o rolled to s top, let the clutch out, and then it was fine..
    but ya mine starts hurkin and jerkin after 4-4.K rpm's
    fitz.. how much am i lookin at here... if i take the eninge out and have them put it back in... 500?
    if itsmroe than that, ill live with it..
  9. Ltdave
    Ltdave Member
    schooter...
    get a hold of MiCarl down at www.thundervalleypower.com and ask him about it...
    hes in plymouth. a bit of a haul from elkton but if you can get it there, he can take care of it for you if you decide to not do it yourself...
    he wont steer you wrong...
  10. MN-Maxims
    Saint Paul, MN
    Stereo is right about the dogs wearing off and the gear where they ride round off also. There is a fix for the 1100's but I don't know if it applies to the 700's
  11. RickCoMatic
    The problem is that Second Gear is Not fully engaging due to the Shift Forks being Bent ... or, the Gear Drive Dogs are "Rounded-off" and the Gear which Your Second Gear is being powered from ... is slipping-off the Dogs (Shelfs that engage on the sides of the gears) and losing contact.
  12. bigfitz52
    LtDave is right; get ahold of Carl and see what his price would be. Probably considerably cheaper if you yanked the motor and took it to him in the back of your pickup.
  13. b0Rn2bL8
    b0Rn2bL8 New Member
    SF East Bay, CA
  14. stereomind
    Tulsa, OK
  15. schooter
    well i emailed micarl via his website... just waiting on the bad news...
  16. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I've done the emergency guideectomy, the piece I pulled from a friends 750 was so big I had to cut it in two inside that little hole before it would fit out! Not pretty, but like the posts above say, that problem causes a 'no shift' situation, not a slip or a skip
  17. chacal
    Born....that piece came out from inside the engine??
    Whoa...........
  18. b0Rn2bL8
    b0Rn2bL8 New Member
    SF East Bay, CA
    Ace_Frehley, I appologize for the off-topic post. You are right, mine was a "stuck in first" situation.
  19. MiCarl
    Schooter, you have an email.
    Thanks LT and Fitz for the plug!
  20. MiCarl
    **UPDATE**
    The email has not been sent. Apparently my ISP cannot handle a number that large. :twisted:
    Perhaps it'll go later after they get their servers upgraded.....
  21. schooter
    ouch.... micarl you're killing me.. ya i dont have an email.. ro a pm..., but thanks
  22. MiCarl
    I sent you the highlights in a PM. I'll find a way to get the stupid email to go tomorrow.
    Sorry for the delay.
