Top End Rattling Noise
Discussion in 'XJ Technical Chat' started by robvoi, Feb 19, 2012.
  1. robvoi
    robvoi Member
    Hey guys, '81 XJ550 Seca, finally have it running; took it out for a longer ride and i noticed that after 10 minutes of the engine running I get a clacking/rattling noise at the top end? What am I looking for? Valve adjustment? Valve stuck? Any help will be much appreciated.
    I am looking to have the engine running smoothly without too much noise.
    Thx
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Valve adjustment check first. All have to be in spec. Then check the cam chain tension.
  3. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Howdy, if you are mechanically inclined, take the cam cover off and check to see if you have too much slack in your cam chain. If you do find too much slack, check your cam chain tensioner, I'm not sure whether you have a manual or automatic, to tell which, a manual has a bolt with a lock nut. If you have checked the tensioner and it's at it's limit, you may have to change the cam chain. How many miles on the bike?
  4. robvoi
    robvoi Member
    Thank you for the reply guys ... finally something for me to other than riding around ... :D
  5. robvoi
    robvoi Member
    I have 18,700 miles on the bike; it sat in my garage after cleaning it thoroughly for 2 years and before it was stored outside for about 15; had a shop that specializes in old bikes get it running; not sure if they did the, adjust valve first, synch carb second
  6. bigfitz52
    Valve clearance check here: http://xjbikes.com/Forums/viewtopic/t=14827.html and part Deux: http://xjbikes.com/Forums/viewtopic/t=29209.html
    Your cam chain has a manual adjuster; directions as follows:
    STEP 1: Remove LH crank-end (ignition) cover. (Use of impact driver shown)
    Start there; if the noise doesn't get better let us know.
    It could also be a loose exhaust pipe at the head, an exhaust component anywhere rubbing/vibrating against something, a relay broke loose and vibrating against the valve cover, or one of many other possibilities.
  7. robvoi
    robvoi Member
    Thank you. I looked for the cam chain adjuster but I must be totally blind (apparently when you're over 50 it'll happen). I'll look for it again and follow the adjusting procedures.
    Thx again
  8. bigfitz52
    You're not the only one here over 50-- look at my first bike (in my sig) and do the math.
    It's on the back of the cylinders, in the middle, underneath the rack o'carbs. Look in from the right side.
