Trouble putting on headers/mufflers
Discussion in 'XJ Technical Chat' started by hohenstein23, Jul 15, 2015.
  1. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    I can not figure how to put on the downpipes and collector on. I am having trouble lining everything up. I have the down pipes unhooked from collector now and still can't get it. Is there a trick to get them on or is it just hard
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    No tricks...leave everything loose until the entire system is installed. Locate the exhaust pipes and crossover. Locate the two inner headers. Locate the two outer headers. Lay on the ground push up on the collector and wiggle each header to start it in the hole. Continue this process until the headers are fully seated in the collector donuts (it should be a tight fit). Snug the header nuts across all four. Gingerly push up and down on the collector to allow any adjustments to settle. Snug the collector bolts. Snug the exhaust bolts. Torque all nuts and bolts to spec. Hope thos helps.
    Gary H.
  3. hogfiddles
    1. I put put everything together very loosely, to the point where no bolts are tightened at all, it's rather floppy.
    2. Then I slid the whole thing under the bike with the bike on the center stand
    3. I'm over 6ft tall, so this works for me-- i lay down along side the bike with a foot under a muffler. I can lift the back of the exhaust with the foot as needed. I line up the exhaust pipes with their holes and get the collar nuts just on by a few threads so the front is hanging very loosely in place.
    4. Slide down and loosely anchor the rear collector mount---- if it's a 650maxim you can skip this step.
    5. Loosely install the muffler bolts
    6. Go back to the front and tighten all the collar bolts til almost snug---the lower bolt are still loose to all pipes to wiggle and "rotate" a bit. Then, tighten the lower bolts and finally tighten the collar nuts. That sounds like a lot, but it's really a short process of tightening things evenly, so they stay lined up, that's all.
    7. Tighten the center bolt, if not a 650 maxim.
    8. Tighten the muffler mounting bolts, and muffler clamp bolts
    9. Tight the crossover pipe union if its a 650 maxim
    10. Get on and go for a ride
  4. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Don't listen to them. There's probably something wrong with your pipes. I'll buy them off you. :D
  5. Polock
    The down pipes are numbered and only fit one way.
  6. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    I think putting on pipes is an art form
    or just a huge form of frustration
    I think it took me a good hour to get mine on this spring
    it is a very frustrating puzzle
    but yes loose then slide it all together and tighten
    the only way
  7. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Ok I got them on I had the down pipes and collector together but muffler separate. I had a car jack under the collector just to hold it so I could Line up the headers. It was a pain but I did it and it's done
    rocs82650 likes this.
  8. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    And I was just about to give them away to bald wonder lol
    BaldWonder and Stumplifter like this.
  9. rocs82650
    Middle Tennessee
    Lol!
    Gary H.
