trying to find a part number '84 XS400 Maxim
Discussion in 'Other Motorcycles' started by alexdc03, Jul 14, 2010.
  1. alexdc03
    alexdc03 Member
    I am leaking a bit of oil from a seal near the front sprocket but the seal doesn't show up on the dealer pictures. When I remove the left side cover from the sprocket area, I have 4 seals to which I can replace,
    1, output sprocket shaft seal
    2, shift rod seal
    3, nuetral light cover o-ring
    4, top left corner slightly above the nuetral light cover has a 2 inch rod going in to a seal and held in place by the side cover.
    Its number 4 I need but its not to be found.
    Anyone have access to part numbers or diagrams which give a part number?
  2. Rural_Guy
    Rural_Guy Member
    Smiths Falls, ON (Ottawa)
  3. alexdc03
    alexdc03 Member
    Yeah been through the pictures a million times, you can see where the seal goes on the crank case picture but no reference to the rod of shaft that sit there in any of the parts sections.
