Trying to Revive! 82 XJ650
Discussion in 'For Sale, Trade/Swap, Wanted' started by Edward Nieves, Jan 19, 2018.
  1. Edward Nieves
    Edward Nieves New Member
    Chicago
    Ok gents and ladies. I have an 82 650xj. Stored it for 2 years. Put it away running. Now the damn thing won’t start. New battery and new plugs. Was cranking it for a bit and only got it to backfire a few times. Even sprayed some starter fluid into the air intake and put a little gas in the plug holes. Still nothing. After a while my starter solenoid started to smoke. Now it sounds like a ‘spin’ noise in there.
    What do you guys recommend I do first to get this back on the road?
    Or does anyone want to purchase as is for $500?
    church of clean for the carbs if it is backfiring your halfway there.
    most likely your pilot jets are clogged and the enrichment circuit is clogged
    also replace your smoked solenoid.
    IN THE CHURCH OF CLEAN
    look at this link to understand fuel and air flow through your carbs
    Something New, Something Naked
  3. Tim O
    Tim O Active Member
    Charlottesville, VA
    Sorry you can't revive the Blackhawks
    Go Bruins:D
    Before you stored it, had any work been done to catch up on long-term maintainince, or did you just buy it running and ride it?
    I'm asking so we can establish a basline for how to move forward with diagnosis and repair.
  5. hogfiddles
    If you put it away running, I bet it ran out of gas.....:D
    Rsk_141 likes this.
  6. Edward Nieves
    Chicago
    Ha! Comedians in this group! I’ll check out that church if clean!
    For the others I bought it running and working fine!
    As for the hawks?? They’re rough. But remember when we ass raped the bruins for the cup? Yyyyep
    Tim O likes this.
  7. k-moe
    Thanks for the reply.
    Odds are that the age-related maintenance items have never been done. Check the intake boots for cracks, just go ahead and do a full teardown of the carbs (replacing the throttle shaft seals and idle mixture needle o-rings). Plan on this winter being your season to refresh the bike so you can enjoy riding, instead of chasing new problems every few months.
    Start by reading The Information Overload Hour ( via the Read This First link in my signature).
    The lack of fire with starting fluid points to an ignition issue. Check that the sidestand swich isn't stuck (a likely issue if you had it up on the center stand with the sidestand up), or pull the sidestand relay to check.
    The next likely culprit is spark plug wires (or coils) that have cracked insulation, allowing the magic pixies to roam free.
    You will find other things that need tended to, so be patient and work methodically.
  8. hogfiddles
  9. k-moe
    One telltale as to the state of things: what are the date codes on the brake lines?
  10. Tim O
    Tim O Active Member
    Charlottesville, VA
    Press account - "In the Finals they faced the Blackhawks. The Bruins fell in six games, with three going into overtime, including an epic Game 1 in which a third overtime period was needed before it was settled. The only game Boston lost by more than one goal was Game 5 in which Chicago scored on an empty net in the last 17 seconds." - wouldn't exactly call it a route... and we're both tied with 6 cups a piece :)
    hogfiddles likes this.
