Turbo XJ550
Discussion in 'Hangout Lounge' started by Ky13harbor9, Apr 7, 2016.
Tags:
  1. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    it is my understanding that the factory xj turbo has a beefier motor bearings and such
    does not use standard carbs
    just keep your throttle wide open you will exceed 9500 rpm redline which is what the top end is based on.
    and yes thats a nice setup
    this stats is interesting
    • Carburetion – Turbo
    • Max Power – 84bhp @ 10500rpm (50bhp @ 9000 rpm std XJ550)
    • Torque – 46ft-lbs @ 9000rpm (34ft-lbs @ 7500rpm)
    standard xj 550 has more torque at 9000 rpm
  3. hogfiddles
    And I see by reading the report, it's really definitely not worth doing.... Other than for purely experimental/knowledge-base purposes. Or, the ubiquitous " I wants to try sumpin', that's all...."
    XJ550H likes this.
  4. Kickaha
    New Zealand
    It's worth it for wank value alone
  5. k-moe
    The only issue I have with it is the turbo choice. Lag is no longer something that has to be lived with; it can be eliminated.
  6. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    On an engine this small, you'd have to find a turbo that spools up quickly to avoid lag. I would think something quite small with a high quality bearing.
  7. k-moe
    Supercharger, dual turbo, or multi-vane. The scooters (250cc and below) that I see get turbocharged have virtually no lag, but then they run up to redline insanely fast.
