Turn signals, brake light, neutral light and tach not working.
Discussion in 'XJ Technical Chat' started by Bighappy, Oct 23, 2015.
  1. Bighappy
    Bighappy Member
    Kingston, Ontario
    I have a 1982 xj650 Maxim. I saw in another thread that my problem is probably caused by a 15A fuse. Under my seat the fuse block only has a 20A and three 10A (I think 3). Any idea on where the subject fuse is? I can't ride till I fix it!
  2. SQLGuy
    SQLGuy Well-Known Member
    Well, it's not the main fuse, or the bike wouldn't run. The fuses should be labelled, and one of the 10As should say something like Signal. That would be my bet. If you have the original fuse box, though, it's more likely that that's the problem - the original clips oxidize and lose connectivity, or break. You should replace it with an ATO type fuse box.
  3. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    The bike in the other thread was a 700. 650's don't have a 15amp fuse. Follow the given advice...replace the fuse box. Hope this helps.
    Gary H.
  4. Bighappy
    Bighappy Member
    Kingston, Ontario
    Yup....wiggling the fuse box got it going. New box it is.
    rocs82650 likes this.
