turn signals
Discussion in 'XJ Technical Chat' started by csmith67467, Mar 16, 2010.
  1. csmith67467
    csmith67467 New Member
    i have an 81 650 maxim. i cant get the turn signals to work. when i push the button the dont fash. what is wrong? im sure its the flasher but where in the world do i get a four prong flasher
  2. chacal
    We have good used original flashers available, and they are three-terminal design, not four..........are you sure it's the flasher that is bad? Have you checked to make sure that the wiring is proper, and that the bulbs are actually working?
  3. csmith67467
    the wiring is good ive traced it all. the little flasher box has four prongs on mine
  4. chacal
    That's an incorrect flasher. Does the plug in terminal, off of the main harness, have receptacles for four terminals? The original connectors has only three places (for the three terminals on the original flashers).
  5. csmith67467
    yeah the plug coming off the wire has four terminals. im very confused. cause there are two flashers for this bike correct? one under the tank and the other under the seat. well both of them are four prong. im very confused. idk. all wires are ok i put them up to a voltage reader and there all ok. idk whats going on.
  6. chacal
    Something's wrong...........both the FLASHER RELAY (3 terminal) and the FLASHER SELF-CANCELLER are located under the tank (6 terminal) are located under the tak, but so are some other relays which do use a 4-terminal connector. What color are the WIRES running to this connector?
  7. csmith67467
    well the po rewired alot of things so. that is why i am so confused
  8. vintagerice
    vintagerice Member
    New Hampshire
    You are checking the directionals with the bike running correct?
    Rob
  9. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Well first let me say that the turn switch is known to have issues when it has not been cleaned in 25+ years. You might want to start off there.
    Next the relay, which is located under the fuel tank, needs to be tested. If the relay is bad you can replace with an OEM solution, or go the cheap(and new) route and get an aftermarket relay. This will require that the connectors be swapped around to accomidate the new relay electronics though
