turtle's bike
Discussion in 'XJ Technical Chat' started by turtlemann14, Mar 20, 2009.
  1. turtlemann14
    turtlemann14 Member
    well, i have a few things to ask about
    first off is electrical
    i have either a short or a bad relay and i can decide which it is. when i am riding my bike, it will just shut off power, the neutral switch and the tail light stays on, but the ignition system and the starter have no power what so ever.
    for a while i could just take the seat off and unplug the relay by the left rear blinker (popping it into and out of socket to make it click) and that would get her going again.
    what is that relay?? that is the starting circuit relay or the side stand relay?
    the next few questions pertain to the carburetors...
    my idle screw is all the way out (i can hold it in my hand) and my idle will stay at 2k rpm.
    it started doing this after i attempted to sync the carburetors. (the idle its smoother now)
    some times, it will idle at 1.5k, but once it warms up it goes back up to 2k.
    i have sprayed flammable liquid around the carburetor boots and carburetors, the rpms neither raised to lowered
    i need to check the plugs and get a reading off of them (which i am about to go do)
    any ideas?
  2. greggvickrey
    greggvickrey Member
    Smyrna, Tn
    Turtle, can't help you on the electric but on the carb issue, if you had your carbs off, did you bench synch them before you reinstalled. If not check the FAQ suggestion forum there is a bench synch how to in there that will tell you all you need to know. Also, lots of other carb related how to's.
    Gregg
  3. turtlemann14
    turtlemann14 Member
    no, i synced them on my bike while running (time consuming)
    felt like it gave it more power
    they are withing 1inch of vacuum to each other
  4. greggvickrey
    greggvickrey Member
    Smyrna, Tn
    I assume, you vac synch'd them on the bike. I may be wrong but, I believe for the vac synch to be accurate you must bench synch first. Guys, correct me if I'm wrong. You need an accurate base starting point for synching the carbs, bench synching gives you that base.
  5. Daplumma
    Daplumma Member
    Unhook the cable completely to make sure its not holding the carbs open.
    Joe
  6. texasfisherdude
    texasfisherdude Member
    Dickinson Texas
    I say fuse block but what do I know I'm a noooooob
  7. midnightblu
    midnightblu Member
    Austin, TX
    turtle, so we can help you and not send you down a rabbit hole chasing the wrong problem can you provide a little more detail about what you did and why?
    important things like did you physically remove any part or the entire carb asembly during the sync?
    and other important factors like what it was doing before that made you want or need to sync them.
    it sound like to me what started as a weekend tweek to the bike is turning into the school of carburators (dont worry plenty of us already have our Doctrine on the XJ's regardless of wether we wanted it or not)
  8. turtlemann14
    turtlemann14 Member
    glad you do have the doctrine :)
    i could hear that one cylinder was firing harder or less that the other three
    you know that dadadapa dadadapa sound
    i believe is was the #4 carb that was to high
    so sync them i got a reading off of the #3 carb then set the #4 carb
    got the reading back off of the #3 and went to #2
    back to #3 for reading and then went to #1
    i did not mess with the jetting
    when i took the plugs out a few minutes ago they where pretty wite, more wire than i like to see but there was still some brown on them (except for the #2 which i believe has a stuck float [my next project], it was black)
    at idle all of my carbs should be running 21-22 inches of vacuum
    nothing was removed, screws where turned and that's it
  9. turtlemann14
    turtlemann14 Member
    i have another electrical problem
    when starting my bike its cranks over quickly, but will not start until i let off the start button
    if i am lucky enough to let off at the right time it will start right up
    seems like the starter is taking all of the power and the coils do not get enough
    maybe time for a new battery of maybe install resistors in the starters wiring?
  10. TheHound
    TheHound Active Member
    Scotia, NY
    Right, if your battry is spent it can have enough juice to turn the bike over but, not enough to fire.
    I would check the generator first to see if it is charging.
    With the rpm's above 2K check the voltage across the battery.
    It should be 14.5v.
    Let us know how you make out.
  11. bigfitz52
    ding-ding-ding Bob, tell the man what he's won!
    I would not have believed this particular phenomenon had I not experieced it for myself. When it happened to me, the motor was spinning PLENTY fast enough to start, but NO SPARK. While checking for spark, I noticed it sparking as soon as I released the button.
    It's a peculiarity of the TCI ignition. I've NEVER had a car do that ever. Most of my previous bikes were kick-starters.
    FULLY charge your battery, install new plugs. See what you get.
  12. turtlemann14
    turtlemann14 Member
    ... your going to kill me
    previous owner messing with the wiring NEAR THE FUSES...
    yea, the fuse of the red wire under the seat was corroded inhibiting flow
    brushed it off and put dielectric grease on it and she started firing while starter was running
    fuse block is my next mod, along with fixing up the "patches" made by the previous owner
    i am still lost on the carbs though
  13. turtlemann14
    turtlemann14 Member
    so about the carbs that don't like to let the bike go under 2k rpm unless they are cold
    my bike starts really easy when cold out, probably more easy than once its warmed up. do you think that the pilot system needs enriched?
  14. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    I would agree with Daplumma.
    I bet your throttle cable is not allowing the throttle to close all the way.
    IF the idle screw is pulled out, and they are close to snyced, that's the only explaination I can think of.
    OR something else is binding on the throttle shafts and keeping them from closing.
    From the sounds of it you are also very lean which can do weird stuff also.
    Also check the choke cable and make sure they are completely closed.
    Mine had a "high idle" one morning. About 10 miles later I realized I didn't close the choke after I left it warm up while I took the garbage cans up to the house.
