Uh Oh
Discussion in 'XJ Technical Chat' started by Jeremyw, Jul 21, 2008.
  1. Jeremyw
    Jeremyw New Member
    Iowa
    My 92 xj600s petcock went out, Filled up my engine with oil, I fixed the petcock, changed the oil and filter and now when I try to start it It dont turn over, there is a noise from the starter but it isnt enough to turn it over. Is there something else I have to do before it will run again.
    Please help!!! I just bought it and have put less than 15 miles on it myself.
    Jeremy
  2. bluepotpie
    bluepotpie Member
    Londonderry, NH
    sounds like a low battery. try charging it up.
  3. stereomind
    stereomind Active Member
    Tulsa, OK
    also, make sure all the connections are tight, esp. ground, and the positive terminal from battery to solenoid, and from solenoid to starter.
    If all that checks out, try jumping the big solenoid leads across with a good size screwdriver, and see if that makes it turn over.
  4. redfire
    redfire Member
    Arkadelphia, Arkansas
    also pull the spark plugs and check for large amounts of fuel first thing, to prevent a hydraulic lock and possible bent rods
  5. treybaxter
    treybaxter Member
    Mississippi
    Just do the basics. Clean your terminals, check for corrosion, check the water level, make sure it's charged. If you doubt your battery, slap in a new one for around 35 bucks.
