Under-seat grab bar on 750 Seca?
Discussion in 'For Sale, Trade/Swap, Wanted' started by tomestl, May 6, 2008.
  1. tomestl
    tomestl Member
    St Louis, MO
    Looking for this bar for the "right" OR LEFT side of a 750 Seca - this photo is the left side. Did Secas come from the factory with a bar on both sides? This is a photo I sent to bikeboneyard, or somewhere, but never got a reply.
    Thanks!
    [​IMG][/img]
    http://i278.photobucket.com/albums/kk11 ... rabbar.jpg
  2. rescue76
    rescue76 Member
    Corbin, Ky US
    Re: Under-seat grab bar on Seca?
    I think they are interchangeable. if not.. I took the one of my right side when I put my back rest on. If your interested.
  3. tomestl
    tomestl Member
    St Louis, MO
    I should check if they are interchangeable... either way I'd like one for the right side, so if you know yours fits I am interested. And the bolts if you didn't use them for the back rest, but I am sure I can get bolts at the hardware store. Price shipped to 63125?
    Thanks, and if your avatar is a FD badge - thanks for what you do!
  4. rescue76
    rescue76 Member
    Corbin, Ky US
    Ill get a price check on the shipping...I used the bolts to bolt the back rest on with...
    Thanks for the recognition. We dont get it around here much.
  5. tomestl
    tomestl Member
    St Louis, MO
    You're welcome!
    Thanks for offering the bar, I'll wait to hear back from you.
  6. donhoe
    donhoe Member
    Grand Forks, ND
    interesting, my son's is missing the bar on the right side as well.
  7. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    NEGATIVE, the seca has this bar on only the left side.
    It is used, by me, more for putting the bike on center stand.
    I dont even thing it will bolt on the other side.
  8. tomestl
    tomestl Member
    St Louis, MO
    Every photo I have ever seen of a Seca in my model year range does not have a bar on the right side, but there are similar threaded mouting holes on the right side. My hope has been it was a later available option or dealer accessory - I agree the left side bar is used mainly for hoisting the bike onto the center stand. Having a bar on both sides would make tie-downs much easier to use. Otherwise I'll find some small eye bolts. I haven't yet tried moving my left bar to the right side, but I should check that.
    Rescue76 said he removed the bar from the right side of his bike, so there must be a part that fits. Rescue76... care to help us out here? Thanks, and I still want the bar!
  9. MaximumX
    MaximumX Member
    Ottawa, Canada
    My parts Seca had them on both sides. Of course, it's a 650 so maybe that's the difference?
    Oh yeah... It is/was also a Canadian model...
  10. tomestl
    tomestl Member
    St Louis, MO
    Interesting... I am still expecting rescue76's bar to work, but some comparable measurements may be in order if you'd be willing?
    Anyone out there have a non-US model 750 Seca w/ both bars?
  11. Ass.Fault
    I use a tail bag made for a harley( straps onto a sissy bar "Kuryaken")
    It has a D Ring in each corner.
    The front (left and right) DRings are straped to the top mount for the rear shocks, each side respectivly of course.
    The rear two are both straped to the rear grab bar.
    This is on a 750 SECA, other model may not apply
  12. MGM8675309
    MGM8675309 Member
    Fort Worth, Texas
    AF is correct on this, LEFT side only on the grab bar. Due to the "left" side bends it won't fit on the right side. If you measure the bolt holes on both sides you will find the distance on both sides identical, making you think there should be a grab bar available for the right side. The parts diagrams i've seen do not show a right side grab bar.
    What I think the bolts holes are for is the optional saddlebag/tail trunk mounting bracket.
    Anyone with the rear bag combo can confirm this?
    And if you have the saddlebag and/or tail trunk, do you also have a rear grab bar?
  13. jims81xj
    jims81xj New Member
    indiana
    my 81 550r seca has left side only, i would love to have a right sider.
  14. TIMEtoRIDE
    Seca 900 ' s have both sides also.
    Just make one.
  15. rescue76
    rescue76 Member
    Corbin, Ky US
    Interesting. I could of sworn I took the grab bar off the right side...guess I should have taken notes.
  16. TheHound
    TheHound Active Member
    Scotia, NY
    My '82 seca 650 has grab bars left and right.
    So they do exist.
  17. tomestl
    tomestl Member
    St Louis, MO
    Just to confirm... no right side bar on yours either?
  18. rescue76
    rescue76 Member
    Corbin, Ky US
    Guess not. Its been a while since I took it off. and I looked around on several websites and tech boards and none of them show the 82 seca 750 having the right side grab rail.
    Its instead called the standing handle. And the OEM replacement for that years is only one for the left side...the diagram does not show one for the right side.
    yamaha-motor.com
  19. tomestl
    tomestl Member
    St Louis, MO
    I checked the Yamaha Parts Diagram and it doesn't show one for the 750 which is why I thought it may have been a later option/dealer install. The bars shown for the 650 and 900 look to be a different shape. Thanks for the offer, and thanks to all for the additional info. The search continues...
    Cheers!
  20. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    The grab handle on the left side is to put the bike on the center stand. They can be duplicated easily. I made another one identical to the stock one. I used a piece of 1/2" heavy wall tubing, bent to match the stock one and smashed the ends with a BFH (big f--in' hammer) and drilled the holes in the ends to mount it. I painted it black to match the other side. It's handy to have it with a cargo net for strapping stuff down. PD
