universal/cross joint
Discussion in 'XJ Technical Chat' started by truckerbikes, Dec 30, 2009.
  1. truckerbikes
    truckerbikes Member
    queensland australia
    84 xj750 is the ride. the problem is it has now destroyed 2(two) universal joints. i have another on hand but want to know has anyone come up with a solution to lubricting these mongrel things so as to stop this from happening again. one thought i had was to cross drill it and then tap a grease nipple into it. but after reading some other thoughts in here about that, forget that idea. my next thought is to drill a small hole into each end cap and pump them with htb grease then plug the holes with rubber grommets. youe thoughts and suggestions please people
  2. schooter
    how many miles on the bike? I've never heard of one failing.., and 2 of them, man
  3. schooter
    I looked at your gallery... and you have a 900 seca frame with a 750 engine.... maybe a little different
  4. TIMEtoRIDE
    One thought is to check for a possible mis-alignment.
    The grease should be some kind of "moly" or top shelf synthetic.
    At worst, these "U" joints should be cheap, as they never fail.
  5. RickCoMatic
    Very unusual.
    Very, very unusual.
    I'd be looking for something loose causing the U-Joint to have unusual stresses placed upon it.
  6. truckerbikes
    truckerbikes Member
    yeah i think the japs ran out of 900's for a while and had a heap of 750 engines laying around so started puting them into these frames and they worked. (just to keep production going)
  7. truckerbikes
    truckerbikes Member
    everything i have checked tells me it is all lined und running true. i get no vibration from the driveline at all, but after looking at this last uni joint it seems to me that lube is the problem or i should say serious lack of it
  8. RickCoMatic
    I guess you have no choice but to drill 'em ... Tap em and put-in a Grease fitting so you can push some grease in there.
    I wouldn't leave the Zerk Fittings in the Yokes, though.
    I'd close the drilled holes with Allen Headed Pipe Plugs.
    Well, ... Allen Headed Plugs ... (of some kind).
    The aluminum or titanium one the NOS Gas Boys use would be good.
    A little LockTite.
    Badda-Bing ... Badda-Boom!
  9. ol_750
    ol_750 Member
    Newcastle Australia
    Hi Guys
    How did it go with the mods to the Uni joint ??
    My 84 XJ750Rl has done a joint too. A new one from the Frasers cost me $350.
    Seperate question for Trucker ...is your engine 45T?
    Cheers Andrew
  10. truckerbikes
    truckerbikes Member
    ol_750 yes the engine i am running at the moment is a 45T.. why do you have a problem
