Valve adjustment tool?
Discussion in 'XJ Technical Chat' started by MattiThundrrr, Apr 22, 2015.
  1. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  2. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Honda sells something similar but hav never used. I like using the zip tie method
  3. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    the thing about the tool is if you do it wrong bad things can happen
    with the zip tie.. no foul no harm
    plus it is cheap and easy
  4. FtUp
    FtUp Well-Known Member
    pacific northwest
    I have one of those and they suck. I prefer the zip tie method.
    FU
  5. k-moe
    That tool is for the later machines (Xj600 and such). The zip Ty method has its faults too.
    hogfiddles likes this.
  6. hogfiddles
    Every method has is pluses and minuses. Some people like the bolt-on bucket holder, some like the wire, some like the ziptie. I have two of the bucket holding tools, but I prefer the zip tie method. For me, the bucket tool is nothing but a pain in the neck. I can have most of the shims checked, Using the zip tie method, in the same amount of time it takes me to get the bucket to stay down far enough, using the tool, to check one shim.
  7. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I have only used the bolt on tool . . . Yeah it can be sketchy at times.
    However i currently know every size shim that is installed, this last Sunday #1 Intake was tight. Only had to use the tool once.
    Have to admit I wrestled with it a few times and suddenly a tiny voice in the back of my head was saying "a lot of guys use the zip tie, I think there is a large one in the basement . . . . maybe you should try it." ;)
    So, what exactly is "The Way of the Zip Tie Procedure"?
  8. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I think fitz did a write up on the zip tie method. I had it saved but I can't find it anymore. Maybe someone else can. I have the tool it took some practice to get it right but now it's pretty ez. I just changed out two shims a few weeks ago and things went smooth.
    Toomanybikes likes this.
  9. k-moe
    Pull the spark plug, open the valve, stick the zip-ty between the valve and the seat (double the ty up and tape it), rotate the cam 180º, remove the shim.
    I really prefer to use a length of insulated 12gauge copper wire. There is a chance that a zip-ty will break after repeated uses, and the wire is easier to fish into place.
  10. Rooster53
    Stumplifter likes this.
  11. hogfiddles
    I don't know of anyone that has bent a steel valve with a thin piece of plastic
  12. Polock
    if the valve can move side ways far enough to crack the valve stem seal, the valve guide is so shot your motor didn't run in the first place
  13. Rooster53
    How about rotating the motor too far in one direction causing the piston to hit the valve with the zip tie still in place?
    Not totally conclusive, but one case of suspect after using the zip tie:
    http://www.xjbikes.com/forums/index.php?threads/problems-after-valve-adjustment-thoughts.48389/page-2
    http://www.xjbikes.com/forums/index.php?threads/need-some-82-xj1100j-exhaust-valves.48437/#post-430775
  14. k-moe
    The bucket holding tool places the valve just as far into the combustion chamber as a zip-ty does.
    You should only be turning the motor over in one direction.
