Valve adjustment
Discussion in 'XJ Technical Chat' started by Colton townsend, Jun 26, 2016.
  1. Colton townsend
    Colton townsend New Member
    Henderson ky
    I have a question what are the intake and the exhaust shim specs on a 82 xj550?
  2. dkavanagh
    Rochester, NY
    Intake valve clearance (cold): .11-.15mm
    Exhaust valve clearance (cold): 0.16-0.20mm
    That's really not shim specs, but if you look up on the chart in the service manual, you can tell what to use based on clearance and what you currently have installed.
  3. Colton townsend
    Henderson ky
  4. Colton townsend
    Henderson ky
  5. k-moe
