Valve clearances.
Discussion in 'XJ Technical Chat' started by rob_lit79, Mar 29, 2009.
  1. rob_lit79
    rob_lit79 Member
    Wichita, Ks.
    I just checked my valve clearances on my 80 650 maxim. It has 49,568 on the clock. I have no idea when the last valve adjustment was. I use the zip tie trick to get the shims out. Here is what I have.
    cyl. #1
    INTAKE shim: 2.80mm EXHAUST: shim: 2.75mm
    clearance: less than .05mm clearance: .08mm
    cyl. #2
    INTAKE shim: 2.70mm EXHAUST: shim: 2.70mm
    clearance: .08mm clearance: .10mm
    cyl. #3
    INTAKE shim: 2.75mm EXHAUST: shim: 2.70mm
    clearance: .08mm clearance: .13mm
    cyl. #4
    INTAKE shim: 2.80mm EXHAUST: shim: 2.80mm
    clearance: .05mm clearance: .08mm
    The smallest feeler gauge I had went to .05mm. Intake #1 is so tight that I could not even get .05mm to fit. I could tell the valves are in need of adjustment by the sound of the exhaust. From the charts I'm looking at the shims I need:
    cyl. #1
    INT 2.70mm EX 2.65mm
    cyl. #2
    INT 2.65mm EX 2.60mm
    cyl. #3
    cyl. #4
    INT 2.70mm EX 2.70mm
    If someone would double check me for any mistakes. Is it possible to reuse some of the old shims on the ones that need that size and just order the ones I don't have?
  2. dpawl31
    dpawl31 Member
    NH, USA
    from what I have heard reusing shims should only be a temporary thing. the aftermarket shims chacal sells are only $7 vs $17 oem.
    can't verify your numbers as I'm on my cell in the car lol
  3. rob_lit79
    rob_lit79 Member
    Wichita, Ks.
    Lol. I'm always on YIM on my blackberry everywhere I go. I just want to make sure that I order the right shims.
  4. goser
    goser Member
    Waterloo, Ontario
    Numbers look good to me.
  5. bigfitz52
    Looks like you used the chart, and they all look good to me.
    Old shims are only good for testing; I would NOT recommend using them, especially with as many miles as your motor has. Using worn shims can result in cam lobe wear, not a good thing. Plus a spit shim can destroy your top end.
    Remember no magnets! when pulling the shims.
  6. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Fitz,
    Why no magnets? Just curious.
  7. TIMEtoRIDE
    Very tiny iron particles are constantly being made by the chains and transmission gears. If the shims get magnetized, these particles would collect there, probably standing on end too!! Then the cam lobe comes down with 200 LBS of force, fifty times a second.
    Now a couple powerful, tiny magnets in the oil filter housing would be a great idea. I've been sticking magnets to the outside of car oil filters for years.
  8. dpawl31
    dpawl31 Member
    NH, USA
    haha I think fitz meant SPLIT shim not SPIT hehe.
    magnets in the oil housing, now theres an idea I like!
  9. bigfitz52
    No, I meant SPIT as in spit out from between the top of the bucket and the cam, at speed...
  10. dpawl31
    dpawl31 Member
    NH, USA
    Wouldn't that SPIT cause the cam lobe to SPLIT it?
    hehe :)
  11. bigfitz52
    Doubtful. They're hardened. The aluminum head casting is not...
  12. rob_lit79
    rob_lit79 Member
    Wichita, Ks.
    Thanks fitz. Yes I did use the chart and I read about not using magnets before I ever pulled the valve cover. Some of the shims I could not read the numbers on so I used my digital calipers. I bought it right before I stopped working as a machinist and have not had the opportunity use them much since. It is almost time to have them recalibrate again. Hopefully this will fix my idle after it warms up. It runs and idles great when cold but once it warms up the idle varies as much as maybe 300 rpm. And there is a difference in tone between the mufflers. One sounds just right while the other has a bit of a popping sound to it. I have been wanting to get these valves adjusted so I can finish my tuning of the mixture screws and syncing the carbs.
  13. bigfitz52
    +1 Rob. With valves as tight as a couple of those are you won't have much luck carb tuning. You will be flabbergasted at the difference it makes. You THOUGHT your bike was powerful before; wait until you get the valves done and the carbs sync'ed. With that many miles, it was in sorry need. Glad to help.
    Keep the flame---Fitz
