valve clearence
Discussion in 'XJ Technical Chat' started by j13jcg, Jul 20, 2012.
  1. j13jcg
    j13jcg Member
    when checking the valve clearence does the pistons have to be at top dead centre ??????????/i
  2. bigfitz52
  3. j13jcg
    j13jcg Member
    i have a manual and was going by it . it said ti set the t on the timing and that would leave the piston top dead centre on cylinder 1 and then check the valve clearence , wats the difference
  4. bigfitz52
    The manual doesn't (or shouldn't) say to use the "T" mark for valve adjustment; do it the way I show in the article.
    The difference is that you need to check the clearance when the cam is pointed squarely away from the valve; and that won't be at TDC.
  5. j13jcg
    j13jcg Member
    i bought a genuine xj700 manual as im no expert . and was setting the valves today and thats wat it said but it didnt seen right . i will do iy ur way , thanks for the pics
  6. bigfitz52
    You need to read the manual more carefully. It's not "my way" it's how it's done.
    The "T" mark is for TDC. It was probably explaining about setting camshaft timing, not valve adjustment.
    Go to the front of the manual, to the "maintenance" section. "Valve Clearance Adjustment" is generally the first item.
    In there you will find this statement, or something quite similar:
    "The proper position of the cam when measuring valve clearance is with the cam lobe directly opposite the valve lifter."
    What they're trying to say is what I explained to you.
  7. hogfiddles
    Bigfitz meant to say that the lobe must be be pointed straight up,at 180 degrees to the face of the shim.
  8. bigfitz52
    No I didn't because it's not.
    It is 90 degrees to the face of the shim; it's 180 degrees from the valve itself. (Same centerline, pointed the other way = 180.)
    Which is why I said "squarely away."
