Valve Cover Gasket 82 Maxim 750
Discussion in 'XJ Technical Chat' started by nyoung48, Jul 6, 2010.
  1. nyoung48
    nyoung48 New Member
    Where can I get a valve cover gasket set. Also looking to adjust the valves while I am in there. Shims needed? What do I need for that adjustment?
  2. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    PM Chacal for a quote
    NOTE: You really should tell people you year/model number and put it into your signature
  3. bigfitz52
    Assuming your bike to be aircooled,
    Here you go, direct from "FAQ Suggestions:" http://xjbikes.com/Forums/viewtopic/t=14827.html
    When you replace the gasket, be sure to replace the metal/rubber composite "donuts" on the bolts. They are what does the work of actually pushing the cover against the gasket, as the bolts themselves have stop collars.
    Oh, and use a metric feeler gauge. I was using an "Imperial" (American) marked gauge in some of the photos, a purely metric gauge is a bonus.
