Valve cover gasket
Discussion in 'XJ Technical Chat' started by pygmy_goat_, May 18, 2015.
  1. pygmy_goat_
    pygmy_goat_ Member
    Exeter, NH
    So, I was looking through my receipts this morning, and I noticed that I replaced the valve cover gasket in 2009. I also replaced the donuts at the same time.
    I have an oil leak somewhere. I'm hoping it's not the head gasket, but I'm not sure. I haven't tested the compression, but I will when I get the bike back together. However, I'd like to order all my parts at once if possible, and I'll need new valve shims and a couple other things, possibly including the valve cover gasket.
    Any thoughts on how long these things last? All of a sudden 2009 is 6 years ago...
  2. pygmy_goat_
    pygmy_goat_ Member
    Exeter, NH
    Bump?
    Is there any sense at all in putting the old gasket back on? It does not look bad, but I do think it was leaking at least a bit before. Maybe the bolts were slightly loose (I don't think that's really possible since they bottom out...)
    A week ago I'd have just bought a new one and not thought twice, but I just got laid off...
  3. hogfiddles
    I'd put it back on and see what happens.....the worst it could be is that it does leak. Then you know. If it doesn't leak, keep rolling
    I'd clean it and reuse. if it does leak you can put on a narrow bead of RTV to stop the leak (I mean narrow....narrow. almost can't squeeze it out of the tube narrow). I'd even use Loctite 515 since it can be used as a gasket dressing, but it might be a bit harder to remove.
  5. pygmy_goat_
    pygmy_goat_ Member
    Exeter, NH
    Perfect, thanks guys.
  6. Haapala
    Haapala Member
    WA-USA
    Related question: I'm gonna replace the valve cover gasket on my Seca pretty soon, is there anything else o should replace while I do that?
  7. k-moe
    That depends on which Seca you have (and which year).
    Seca 400? Seca 550? Seca 650? Seca 750? Seca 900? XV920 Seca? Seca II? YICS or not?
    What other maintenance have you done? Why are you replacing the gasket?
  8. XJ550H
    the donuts for the hold down screws and while your in there check the valve clearances
  9. k-moe
    Not knowing which Seca he has; you may be telling him to buy parts that he can't use.
  10. Haapala
    Haapala Member
    WA-USA
    It's an '82 750. Leaking like a mother from the left side. This will be one of the first things I've done myself on it, just put new tires on.
  11. k-moe
    Then you will need the rubber doughnuts after all. They are what holds tension on the gasket. Chacal also sells a handy little bobbin that helps install the new doughnuts onto the bolts. Definitely check valve clearances if you have not done so before. If you have not yet read The Information Overload Hour, do so (link is in my signature). When you put on tires did you check the rear brake shoes for delamination? Are the front brake lines new, or are they still 30+ years old? Master cylinder and calipers rebuilt?
    This is the time to start a thread for your bike.
  12. Haapala
    Haapala Member
    WA-USA
    I had a shop change the tires, but they were doing a full "check up," and they didn't find any problems other than the brake pads. AFAIK, everything is still stock, no rebuilds.
  13. k-moe
    Yamaha called for the entire brake system to be rebuilt every four years (caliper(s), master cylinder, replace hoses). You would be wise to assume that it has never been done. You should also assume that the valves have never been checked or adjusted. Did the shop inspect the wheel bearings?
  14. Toomanybikes
    Tsawwassen bc
    Here's a trick from way back. Clean the engine and use spray deodorant along all gasket points and warm up the engine . Any leaks will be evident as deodorant finds the wet spot
  15. pygmy_goat_
    pygmy_goat_ Member
    Exeter, NH
    Ooo that one is new to me. I wasn't envying trying to get baby powder around the various gaskets. I'll give it a shot!
  16. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Just deoderant? Or does it have to be the antiperspirant type?
  17. k-moe
    IIRC it has to be the powdery kind. Basically the old-school powdery residue deodorant that has been supplanted by the fancy clear stuff.
