Valve job
Discussion in 'XJ Technical Chat' started by Joe34, Sep 25, 2017.
  1. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Well i will be doing my valves tomorrow evening. Stripping it anyway.
    I have 6 or more tight valves out of spec.
    Its at the point where its starting harder and harder.
    So i will take lots of pics along the way. First time doing this. So bare with me i may have lots of questions. Lol.
    I do have service manual, so hopefully that will get me threw it.
    To be continued. ..... . . . . . . . .
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I was nervous the first time I checked and adjusted valves. Procrastinated a long time.
    Now easy peasey after the first time.
    Which bike?
    Joe34 likes this.
  3. XJ550H
    he has a 700X
  4. Simmy
    Halifax, 750x I think, no difference in the valve adjustment to the 700X though.
    Joe34 likes this.
  5. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Yes sorry i forgot to add bike.
    86 750 X
  6. XJ550H
    it is in your signiture maybe expand on it to full info on bike
  7. XJ550H
    same method
  8. hogfiddles
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Signature doesn't show up on the mobile version unless I hold the phone sideways. I'm always having to reload the page to find out.
  10. Joe34
    Joe34 Active Member
    Halifax nova scotia
    @hogfiddles or anyone..is top dead center at the T on the crank or is it the little ] half box tdc.
  11. Joe34
    Joe34 Active Member
    Halifax nova scotia
    So all my exhaust valve are in spec. So I just took intake cam off. Is this ok?
  12. Joe34
    Joe34 Active Member
    Halifax nova scotia
  13. Simmy
    Nothing gained removing the exhaust cam if they're all in spec. Just curious how many intakes you found tight and at what mileage. Mine had about 10,000 kms on it and I found a couple valves tightened up. That's when I found out my local Y dealer didn't have much of a service department. No one there had a clue what I wanted when I asked for shims. This was long before Chacal's excellent service existed.
    Joe34 and Stumplifter like this.
  14. Joe34
    Joe34 Active Member
    Halifax nova scotia
    I had 6 tight on intake side. 56k
    One was like .05mm a couple at .08mm and 4 at .10mm
    All exhaust were .25mm
    I get that at a few Y dealers to. There's a few within am hours drive away from me. Some have no idea.
  15. XJ550H
    Joe34 likes this.
  16. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Got my parts ordered. Should have them Monday or Tuesday.
  17. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Exhaust tells me .21 to .30 is what is recommended clearance.
    Mine were all around .25
  18. k-moe
    He has an X.
  19. hogfiddles
    I forgot--- you have an X, don't you?
  20. hogfiddles
    Ha... I was in the middle typing that while scrolling up to review, and saw my other old post on that.
  21. hogfiddles
    But-- it's not telling you the
    " recommended clearance "..... it's telling you what your ACCEPTABLE RANGE is. Your .25mm is in the acceptable range..... in-spec.
    Joe34 likes this.
