valve noise question
Discussion in 'XJ Technical Chat' started by assassinx1, Jul 11, 2010.
  1. assassinx1
    assassinx1 Member
    hey guys im getting a hissing type of noise from my over heat and a ticking depending ont he idle is the difference in the sound ... idel is ticking, high rpm is the hissing basicly there is so much ticking or noise under the valve it make sort of a hissing, my question is i felt that the adjustment was getting loose causing this issue....but from what i have read the adjustment gets tighter over time, is there something that may get loose that will cause lifter noises or is the adjustment getting tighter causing the prolbem
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    Are you sure it's coming from the engine and not the exhaust?
    When was the last time the valve clearances were checked?
