Valve shim markings.
Discussion in 'XJ Technical Chat' started by whitewolf_00, May 6, 2012.
  1. whitewolf_00
    whitewolf_00 Member
    Kirkland, Wa
    Hey, Im getting ready to place an order with chal for carb rebuild parts, and valve adjustment parts. I have a question. When I pulled the current shims out and wrote down the numbers off it. I have 4 of them with odd markings.
    #4 exhust is 2?75. #3 exhaust is 275a, #2 intake is unreadable. #1 intake 2,825. Any thoughts on what theses are transalted over too? or is there a diffrent way to mesure them to get a idea what they could be? I have some known numbered ones, should I move them over and maybe try taking a new reading so I can get the correct new shims?
  2. mook1al
    mook1al Member
    Talladega, AL
    If you do not have a mic. to measure them with, then yes...
  3. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    +1
    Some shims will have an "a" after the number, some won't.
    Most countries that use the metric system use the comma as a decimal, and a decimal as a comma, the opposite of the way we write numbers.
    So your 2,825 would be 2.825mm. I've not seen a shim that was measured out to the thousandths. They usual go from 2,80 to 2,85
