Valve Shim Removal Question
Discussion in 'XJ Technical Chat' started by crow, Dec 9, 2009.
  1. crow
    crow Member
    Melbourne, Australia
    Having removed the valve cover and checked the clearances the next step is to remove the shims.
    I noticed though that some of the shim buckets have rotated so that the notch that allows you to lift the shim is under the cam shaft.
    In BigFitz's airhead valve adjustment post he writes:
    I'm just wondering how you rotate the bucket to get the notch in the best position.
  2. xyxj650
    xyxj650 Member
    Fergus Falls MN
    You rotate it when the cam lobe is opposite of the bucket.
  3. MiCarl
    Yes, the bucket rotates freely when the cam isn't loading it. The bucket will rotate as the cam pushes down on the shim. Getting the notch positioned so it will rotate into a convenient location is the "art" part.
  4. crow
    crow Member
    Thanks gentlemen. My first time so just wanted to check :)
  5. Broke_Dirty_Maxim
    Broke_Dirty_Maxim Member
    Jacksonville, NC
    I got into the habit of simply holding the notch where I wanted it, after I got it positioned properly, because it has a tendency to spin out place when you are placing the load back on the shim.
  6. Hillsy
    Hillsy Member
    That's assuming the valve hasn't closed up enough to ride the shim on the cam 8O in which case you're in a bunch of trouble.....
    Have a look here:
    http://members.dslextreme.com/users/bik ... ip_tie.pdf
    Cheapest valve lifting tool you'll find. It's written for a GS Suzuki, but the principle is the same (and I used this method on my XJ a few months ago :wink: )
  7. crow
    crow Member
    Hillsy, that's a great document. After reading that, Bigfitz's thread and some of miCarl's stuff as well as the rest of you it all went well.
    Now gotta see if I can purchase aftermarket shims in Oz.
  8. Broke_Dirty_Maxim
    Jacksonville, NC
    I'm not sure if your bike uses the 29mm shims like mine does, but if it does you don't even have to go aftermarket to save some money. For some reason the Kawasaki shims are the exact same thing but only cost about $12 instead $20 something like the Yamaha ones do.
  9. bigfitz52
    and only $7 or $8 from chacal.
  10. crow
    crow Member
    Yep Broke Dirty they do and I'm able to get them here for $9.95 each at a place called ZPower Australia.
    My last chacal order has just dispatched so missed the boat on adding them.
  11. wizard
    Hey Crow, I only paid $8 from Yam' Frankston.
  12. crow
    crow Member
    Thanks wizard. Spoke to Jade down there and all organised.
    I reckon Jade must fancy you (does your first name start with R?) and gave you a good price as I'm paying slightly more but after ringing two local Yamaha shops where the pimply faced youths "didn't think they have them" I'm happy to pay for a bit of old fashioned customer service. Pick them up mid next week.
  13. murray
    murray Member
    Sydney Australia
    Hi crow ,there,s a company in Aus. called Precision Shims that sells all sizes,including the 29mm ones. They priority mail,so delivery is quick. I carnt remember their details,but you can google,or they also advertise in Just Bikes magazine. Cheers, Murray
  14. Bushy
    Bushy Active Member
    Last time I asked Yam' Frankston for shim prices they were $20 each, that was about 6 months ago. Went for used from Pakenham got a mate to pick 'em up, $2 each. Maybe next time I'll tell Jade they are for R? Or Yam' Frankston can take a flying....at the moon!
  15. crow
    crow Member
    Yeah $20 are for the Yamaha ones $10 is for the aftermarket ones.
    Jeez murray precision shims are about 20 minutes from my place will bookmark there site for next time.
  16. parts
    parts Member
    prescott valley az
    be aware though if you go for shipped parts!!!!!!!!!!
    powerpartsplus out of texas had yamaha OEM shims for
    $13.00 each. i ordered 5.
    when they arrived i did'nt like the look-the y/# stamp, did'nt
    come close the the OEM and the quality was diff. 8O
    when i had to buy an additional aftermarket ship from the local
    yama guys ( for $6.oo), i compared them and they were a perfect
    match. :?
    so then i took a second look at the little packs that came from
    yamaha and EACH one had had the staples removed then re-stapled :evil:
    it's not proof of fraud but i know in my hart (like you know when
    your child is really sick) that i was ripped off. :oops:
    accept for Len i won't buy new OEM parts over the e-net any more. :lol:
  17. bigfitz52
    When Len doesn't carry something, or for whatever reason I have to resort to Yamaha as a source, I use Babbittsonline http://www.babbittsonline.com/pages/par ... fault.aspx and have never had any sort of a problem.
    The other cool part is that they're right here in Michingan.
