VIN question
Discussion in 'Hangout Lounge' started by tabaka45, Mar 15, 2019.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Are the VIN stamped into the frame and the engine identification number supposed to be the same?
  2. chacal
    Yes, if it's the original engine for that frame............
  3. tabaka45
    Brunswick, Georgia
    Well, I guess I have a replacement engine, or I am not looking at the right number.
  4. XJ550H
    the number is the short vin on the motor if it does not match the ending digits on the frame vin then you have a replacement motor. you can still run it through the vin decoder
  5. tabaka45
    Brunswick, Georgia
    Thanks. I just checked and it matches. if you had not responded I was going to mention that the engine number was a lot shorter than the frame number.
  6. JetmechMarty
    JetmechMarty Active Member
    Coldwater, Mississippi
    VIN numbers got longer in 1981. I believe the number of characters in the engine number carried on as before.
  7. k-moe
    Not for Yamaha. They got a waiver. The only long VIN you'll find until '83 is on the headstock sticker, and it's just there for convenience.
    My '82 Seca is titled with the short VIN.
    You are correct about the short VIN still being used for the engine.
    JetmechMarty likes this.
