Voltage/Rectifier WTF? - FIXED!! Pics!
Discussion in 'XJ Technical Chat' started by skippy344, Oct 12, 2009.
  1. skippy344
    skippy344 Member
    Aggieland, TX
    OK, so in the process of my fuel flow issues with Rosie,
    I noticed that the Voltage/Rectifier is too hot to touch, and the wiring is so hot that it will soon melt the Molex connector.
    What is causing this?? When she's running, the voltage across the battery is 14.4v.
    Oh, and she still bucks while accelerating, like she is fuel starved.
    I stopped working on the fuel starvation thingy until I figure out what is going on with the too hot V/R and wires.
    Any ideas?
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Re: Voltage/Rectifier WTF?
    Check the connections in the Molex plug. A bad contact leads to resistance witch leads to heat.
  3. skippy344
    skippy344 Member
    Aggieland, TX
    The plug is fine. I recently replaced it. I also used dielectric grease on the connector.
    The connector was melted on one of the alternator wires when I got the bike from the previous owner.
    Don't know why the alernator wire is heating up, or maybe it is coming from the V/R.
    It is a replacement that I got from the salvage yard. The original one has the melted connector.
    I took apart the alternator to see if the brushes were ok, and they looked fine.
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Maybe the battery is not in that good of shape and the alternator is working too hard to keep the charge up thus overheating the wires and regulator. Have the battery load tested and see if its up to par.
    MN
  5. David3aces
    David3aces Member
    St. Pete Fl.
    Clean all the ground connections; Battery to engine connection and harness to frame connection.
  6. skippy344
    skippy344 Member
    Aggieland, TX
    Battery is brand new, 12.8v while off.
    I will check the grounds, but I recently replaced both cables with model correct cables.
    Thanks,
  7. MN-Maxims
    Saint Paul, MN
    OK
    Also is the bike stock or do you have any thing on there that would increase the load on your electrical system, Lighting, radio or ?
    MN
  8. skippy344
    skippy344 Member
    Aggieland, TX
    Stock, except for the Dynatek coils.
  9. Robert
    Have you checked the alternator brushes for length (looks fine isn't good enought I'm afraid)???? They must be within operating length (12-8.5mm max/min)
    They WILL cause a multitude of problems including melting the connector (you ain't alone on that one). Bad idle, flaky electrical issues, the list goes on.
    Be sure to clean up and examine the brush ring on the rotor, use a pink pencil eraser/rubber to gently clean it off. Do a resistance check on the rotor and the stator windings.
    The other culprit for melted alternator connectors is corrosion on/in the supply/return wires!
    The resistance of the supply wires goes up as corrosion does it's dirty work. This occurs since the conductor of the wires are not insulated against moisture. We all wash our rides but this and rain are the reasons we are having problems this far down the road. The water wicks into the wire and the corrosive process begins. See a green connection? If you strip the wire back, you will still find the green corrosion due to this condition. Best fix is to replace the wire and seal the ends to prevent this problem from reoccurring.
  10. skippy344
    skippy344 Member
    Aggieland, TX
    Thanks for all the great advice. Here is my plan...
    I went to an auto junkyard today and clipped a couple of 8 position harness connectors.
    I am going to cut off my melted ends, pull the wires out from my water-tight connector I bought, solder my wires onto the pins and plugs on the new connector and see what happens.
    Pictures to follow...
  11. zrttodd
    zrttodd Member
    Bad Axe,Michigan
    I had the same problem with my 700 X. Fixed the melted wires.Replaced the key switch and that was the problem. Check this web site out www.geocities.com/motorcity/speedway/7795/ it is the xj electrical page.
  12. skippy344
    skippy344 Member
    Aggieland, TX
    Wow, Todd, that site is thorough! I have been studying for the last 2 hours!
    Reading, I have found I have more electrical problems. My headlight comes on as soon as I turn on the key. I see its not supposed to until the bke is running. Gotta go trace that problem too!
    So, possible new key switch, replace reg/rec connector, fix lighting circuit.
    I should be busy the rest of the week, thanks!
    Appreciate the help folks.
  13. skippy344
    skippy344 Member
    Aggieland, TX
    Re: Voltage/Rectifier WTF? - Fixed!
    Rosie lives again! I went an auto salvage yard and found an 8 position water-tight connector and installed it onto the rectifier/regulator harness.
    The wires do not get hot anymore!!!
    Here are some pics of the repair, enjoy...
    You will notice that I have a head gasket leaking oil, but no compression loss. Or, could this oil be coming from somewhere else?
  14. Kracket
    Kracket Member
    Spokane WA
    dang the website does not exsist anymore...
    Just bought a xj650
    the guy said it does not run and it might be something to do with the V/R...
  15. adrian1
    adrian1 Active Member
  16. Shannonside
    Shannonside Member
    Hi,
    Is there a problem if I share that info with individuals who would like to have it ?
    I actually copied that material onto my hard drive a couple of years ago, and it really is fantastic information.
    Don't want to tread on anybodys toes, naturally.
  17. Alive
    Alive Active Member
    Queensland, Australia
    Unless there was something stated in the info when it was posted to suggest it was copywrited or similar. I'd say go for it
  18. amfmtxca
    amfmtxca Member
    God's Country Lubbock Texas
    Looking forward to that posting, I am tackling lots of small problems, dont have a lot of time so I want to get everything working like new so I can enjoy what little time I do have to ride
  19. Shannonside
    Shannonside Member
    Hi folks,
    I rooted that article out, and when I Googled it's title - ''XJ-OWNERS Electrical System FAQ'' - I discover somebody has archived it already - on this forum !
    http://xjbikes.com/Forums/viewtopic/p=184440.html
    Hope it's useful to people, I've surely found it very valuable !
  20. adrian1
    :lol: I posted that link in my post of March 8 :wink:
  21. RickCoMatic
    If the information isn't protected by copyright, ...
    and, ...
    Is Valuable because it contains information which is helpful and correct, ... making it available to others is a nice gesture.
    If there's a problem with it that needs correcting or clarification; bringing it in for others to read may be doing more harm than good.
  22. Shannonside
    Shannonside Member
    :lol: I should have probably run the search in the forum's search facility, but Google gave me that other thread as the first hit. No harm done I suppose :wink:
    As far as RickCoMatic's point goes...
    The top of the document says clearly
    I'll leave it to wiser heads than my own.
